ETR174 Posted September 21, 2014 Author Report Posted September 21, 2014 I watched Sparky's video and he said 1mm is equivalent to 1 degree :/ Quote
ETR174 Posted September 21, 2014 Author Report Posted September 21, 2014 (edited) I looked it up and everyone that did a write up on the timing plate mod said that 1mm is actually 1.136 degrees. Edited September 21, 2014 by ETR174 Quote
Burke Posted September 21, 2014 Report Posted September 21, 2014 IIRC... in that photo he had only ground down the high spots on the plate and hadn't actually elongated any holes because the drill battery was dead?... so you are seeing the project halfway through and he is talking about it completed. You are on 2 different stages. Quote
sprinklerman Posted September 21, 2014 Report Posted September 21, 2014 I watched Sparky's video and he said 1mm is equivalent to 1 degree :/Suit your self. Carry on. Just trying to help you out.I looked it up and everyone that did a write up on the timing plate mod said that 1mm is actually 1.136 degrees. Quote
ETR174 Posted September 21, 2014 Author Report Posted September 21, 2014 I would trust sprinkler or sparky. That sparky dude is clueless on many things.Well it's not just Sparky. AKheathen's write up on the mod said that 1mm = 1.136 degrees. Also when a couple of other people posted about the timing plate mod the people giving them instructions said the same thing. Quote
registered user Posted September 21, 2014 Report Posted September 21, 2014 anyone tried one of these timing plates ? http://www.ebay.com/itm/BANSHEE-BILLET-ADJUSTABLE-TIMING-STATOR-PLATE-DRAG-RACING-/221434378052?pt=Motors_ATV_Parts_Accessories&hash=item338e847744&vxp=mtr Quote
ETR174 Posted September 21, 2014 Author Report Posted September 21, 2014 anyone tried one of these timing plates ? http://www.ebay.com/itm/BANSHEE-BILLET-ADJUSTABLE-TIMING-STATOR-PLATE-DRAG-RACING-/221434378052?pt=Motors_ATV_Parts_Accessories&hash=item338e847744&vxp=mtrIt says its billet so yes that is a good one. Also it is T6 aluminum which is a very good aluminum. Quote
sprinklerman Posted September 21, 2014 Report Posted September 21, 2014 Well it's not just Sparky. AKheathen's write up on the mod said that 1mm = 1.136 degrees. Also when a couple of other people posted about the timing plate mod the people giving them instructions said the same thing.I'll TRY to help you one last time. Measuring the hole is inaccurate. (Hint: you really can't accurately ... there's an arc to the holes,not straight line) Try measuring off a fixed point on the case(like aftermarket degree wheels do) ,use a degree wheel on your crank,and see what you come up with. I'm not saying it a huge difference, but if your off .25mm per degree,or vis versa , you'll be off 1° total. Judging by the quality and accuracy of the pictures you posted, you're not within .25mm on any of it. Quote
91coupemike Posted September 21, 2014 Report Posted September 21, 2014 Quick question on using an engine degree wheel for checking ignition timing. On a car you use a signal from #1 cyl and use a timing light, and I've only used my degree wheel for cam timing, not ignition timing. Line zero up with the crank key and?? Quote
trickedcarbine Posted September 22, 2014 Report Posted September 22, 2014 You need to figure out TDC and BDC. Set the degree wheel to zero with a pointer of some sort mounted on the motor. Quote
