Broza Reid Posted July 29, 2014 Report Posted July 29, 2014 My 09 banshee has a problem in the right bank it gets spark and idles but when you gas it it doesn't fires like the left bank then it pops and farts out the exhaust any suggestions Quote
WINDYCITYJOHN400 Posted July 29, 2014 Report Posted July 29, 2014 Thoughts - Crank out of phase. Flywheel came loose. Flooded on right carb. Inspect flywheel trigger points for corrosion and proper gap. Inspect reeds too. Quote
BurnsideBanshee Posted July 29, 2014 Report Posted July 29, 2014 Check your fuel line to, easiest to rule out, had a line come little loose on mine caused the same issue. Quote
trickedcarbine Posted July 29, 2014 Report Posted July 29, 2014 Has it over heated recently? Done mods and didn't change jetting? Is it eating coolant? Quote
Broza Reid Posted July 29, 2014 Author Report Posted July 29, 2014 I bought with mods done but just the usual bolt on mods boost bottle vforce 3 Reeds pro flow intake KnN filter fmf fatty pipes not shore about jets have not pulled carbs apart to find out i am pretty shore it has not over heated and the coolant is same not eating it I'll check the fuel lines and see if they are loose hopefully that's all it is Quote
Larry's Shee Posted July 29, 2014 Report Posted July 29, 2014 Get rid of boost bottle. Check carb bootsfor cracks, you probably have an air leak on that side. Wouldn't hurt to do a leakdown test. Quote
Broza Reid Posted July 30, 2014 Author Report Posted July 30, 2014 Hey progress report on right bank is the pilot jet was blocked not fully but enough so now shee is firing like a mad machine but my main jet is 330 my pilot is still 25 and my air screw is 1 turn out not too Quote
DTrem13 Posted July 30, 2014 Report Posted July 30, 2014 What's your elevation and riding temperature? I just switched my pilot jets from 25 to 30 and it runs a lot better. I've heard that FMF Fattys require at least a 30 to run smoothly. Mine was running like garbage in the idle - 1/4 throttle area and once I switched the jets it runs a lot better. Quote
Larry's Shee Posted July 30, 2014 Report Posted July 30, 2014 What's your elevation and riding temperature? I just switched my pilot jets from 25 to 30 and it runs a lot better. I've heard that FMF Fattys require at least a 30 to run smoothly. Mine was running like garbage in the idle - 1/4 throttle area and once I switched the jets it runs a lot better. Second time I have seen this ^^^ , maybe from you? Have 27.5 and seems to run good, but difficult to start at times. Might have to try this Quote
Broza Reid Posted July 30, 2014 Author Report Posted July 30, 2014 Elevation is anywhere from 100 meters to 200 meters above sea level and anywhere for 16°c to 40°c Quote
trickedcarbine Posted July 30, 2014 Report Posted July 30, 2014 You need to up that pilot for sure. 27.5 at minimum. But like stated. They like a fat pilot. Quote
Broza Reid Posted July 31, 2014 Author Report Posted July 31, 2014 Ok sweet I'm chasing down a set of 30s now Quote
