Still confused on the custom orderd cylinders comment. How many do you need to order to get a tall enough casting to fit that stroke? What are you refering to when you said lots of machining? I would think adding material would be involved first. When increasing stroke your gonna loose blowdown time unless you raise the exh roof. But usually exh duration gets a little to high. A cylinder cast for larger stroke would have transfer ports lower in the cylinder. Can anyone reputable confirm that this size super can exist?
I didn't graduate high school but own buisness and probably got more money than you do buddy.
Landscaper with one truck and a push mower.
Got "more" money….only because he cashes all his checks and has them pay out in singles because he sees that as MORE money than getting paid with ONE $20 bill.
i would like to see cases modded for 16mm, because from from what i`ve read there isnt much left after 14, its requires welding and or epoxy and is on the ragged edge of surviving...not just "drop in and port"
