Why?
Sent from my DROID RAZR using Tapatalk
They both work fine. No complaints there.
I just like the beefier design of the Mattoon better...As well as the fastener hardware and the way everything is held together better, imo.
like the others have said you can pull the lever regardless off what gear or how high the rpms are. if that wasnt the case there would be alot more bent shift forks.
It would have to be real lite springs (like 1/2 pressure of a stock) to slip on a dirt/trail bike. I would not think there would be enough load on the motor
I power. Shift a 10 mill cub with a lockup all day. Not sure where the lockups dont shift or you cant pull the lever started either. My bike feels exactly like a stock bike at the clutch lever at all rpms and gears. Seems perfect for a mx bike. There is no difference in feel or rideability.
what springs and weight on fingers do you have.
In your application its not worth the money. You could run 6 cut stock springs with a lockup with stock weights and it would apply similar pressure to what you have now. Use the money to find more tq to get you out of the corners.
The goal is to maintain strong clutch pressure while reducing clutch lever effort.
I am certain would smoke my clutch going back to all stock springs.
I checked out the Mattoon a little bit ago.
Looks like they only offer one model that is borderline severe duty? Am I finding that right? Looked like a 10 plate setup over all package/system.
