bjd626 Posted July 18, 2014 Report Posted July 18, 2014 I split the cases and found the bearing on the stator side cracked and the had been put into the hole in the cases this is my first rebuild the pin was pulled out of the crank bearing I'm guessing that's what caused the cracked bearing does it go in there or sit like the two in the middle bearing Quote
sprinklerman Posted July 18, 2014 Report Posted July 18, 2014 Ifyoustuckaperioddomewhereinyourquestionimightunderstandwhatyoursayingandthenidbeabletohelpidbehappytodothstificouldunderstandwhatyouresayingthanks Quote
Starwriter Posted July 19, 2014 Report Posted July 19, 2014 Tapping the space bar on the iphone twice just takes tooooo damn long. LOL. Quote
bjd626 Posted July 19, 2014 Author Report Posted July 19, 2014 (edited) I guess this is a forum to improve grammar.my mistake I was under the impression it was a banshee forum maybe you could help me with both? Edited July 19, 2014 by bjd626 Quote
sprinklerman Posted July 19, 2014 Report Posted July 19, 2014 http://www.bansheehq.com/forums/index.php?/topic/140912-Banshee-Bottom-End-Assembly-Walkthrough Here you go. Hope it helps. Quote
bjd626 Posted July 19, 2014 Author Report Posted July 19, 2014 Big red 350x the walk through is great. I just can't see on the picture of the dowels if the one on the stator side is in the same position as the two in the middle, or does it go in the bottom case? Quote
CottonBranchRacing Posted July 19, 2014 Report Posted July 19, 2014 There should be a divot in one of the case halves at the seem where it matches to the other case half. That's where the dowel pin goes. If your bearing doesn't have a pin, that's fine, it'll be ok CottonBranchRacing Quote
trickedcarbine Posted July 19, 2014 Report Posted July 19, 2014 If you don't have dowels on your bearings, you can put a dab of LOCTITE on them to keep the outer race from trying to spin. Quote
