White smoke right side 04 banshee
That would mean the crank case is not sealed up. Did you do the leak down with the clutch cover off? I'd imagine it's coming from the pto side crank seal and pressurizing the trans case. If it's not the seal it's the sealant used to sandwich the cases.
