Hi everyone,
I'm new to the 2 strokes and need some help!
I have a serious smoke issue on the right side of my banshee. I've done a compression test and both cylinders are 100 psi. On the money! It also starts first kick every time. My question is, if the compression is good does that mean that I can rule out the head gasket?
Try a leakdown test! It still could be a head gasket but sounds like it might be the crank seal. has the oil level been dropping in the crank case?
That would mean the crank case is not sealed up. Did you do the leak down with the clutch cover off? I'd imagine it's coming from the pto side crank seal and pressurizing the trans case. If it's not the seal it's the sealant used to sandwich the cases.
