get a pro mod tranny and moded shift shaft new forks.
or ck eccentric shaft
Sent from my GT-S5360L using Tapatalk 2
When it come it to powerband and you let out it shifts fine but won't wide open shift
Your clutch basket may be really notched up.
As said - Go with a full ProMod tranny, pancake bearing, go thru your clutch and inspect everything.
Mine also does this but the engine is much more stock and it seems to only not want to go to third under a load. The clutch basket is a hinson and is known not to be notched, its almost new. I am also running a pancake bearing.
Is it possible to hit the shifter too hard on these if you have the modded star? Or would the modded star be the issue in this instance?
Thought maybe original poster maybe running a modded shift star as well. Mine has a cascade one in it.
Have you checked the claw on the shift shaft for excessive play, made sure the eccentric is adjusted properly, shift detent arm is ok, shift forks and rods not chewed and bent?
Mine was recently gone threw by Herr Juggs racing so I am assuming its ok on the inside. I did ask him to go threw that part of the motor.
I will look into the eccentric and those parts again before splitting it open.
DDQ that makes it sounds like this is a common issue when the engine work lets it spin up to higher rpm's? I am looking into the promod trans and he reading I am doing suggests that maybe the fix for what I am having issues with.  Mine only does it at WFO, 3/4 throttle its fine.
More so then not, problems shifting come from poor adjustments.. I ran a stock trans on motors ranging from 40-90hp+ without any problems.
