Brandon54 Posted June 30, 2014 Author Report Posted June 30, 2014 My choke tube is COMPLETLY off aswell !! I just noticed . And the choke plunger won't hold itself out . Can a vaccum leak come from the holes on the side of the carb where the tube is supposed to be ? Making it idle terrible Quote
Brandon54 Posted June 30, 2014 Author Report Posted June 30, 2014 Is the choke tube just like a 3/8 line to go to one side of the choke to the other . ? Should I order a new plunger and line together ? Anyone got a reference diagram ? Quote
O/CbansheeRider Posted June 30, 2014 Report Posted June 30, 2014 Probally 1/4. There's a thread another newbie question that has a pic. It was not to long ago. My plunger doesn't stay out and choke functions fine. I pull it out when cold starts up fine and I let it go. Sent from my iPhone using Tapatalk Quote
03DMshee Posted June 30, 2014 Report Posted June 30, 2014 If you really dont wanna hold the choke for that amount of time you can always go out back on moms washline and grab a cloths pin..pull choke insert cloths pin....done.... Quote
Brandon54 Posted June 30, 2014 Author Report Posted June 30, 2014 I don't need the choke to start my bike . Always starts first few kicks . But there's is no choke tube between carb ? Does that make a vaccum leak ? And make it not run right? What exactly is the tube ? Just a piece of line that goes from on carb to the other ? Quote
wayne_smith97 Posted June 30, 2014 Report Posted June 30, 2014 Yes the hose needs to be there. It's pulls fuel from the choke circuit in the left carb and feeds it to the right carb. That way you don't have two choke levers. If the hose isn't there it can/will idle and run like shit. Replace the hose and go from there Quote
iLLiCiT Posted July 6, 2014 Report Posted July 6, 2014 Yeah without the carb hose you will certainly have issues. I believe you can just use any piece of tubing for fuel. probably around 1/4" Quote
