I've got this oversized tank and i need to make it white. I read that spraying is a bad idea as the vapour naturally seeps through the plastic and will make it bubble. I tried some VHT vinyl dye spray but it kinda scratches off with your nail.
Any ideas?
Only other option would be to buy a standard tank and white covers, but would rather use this one if poss!
Rit dye was the 1st thing I tried. Had a smaller tank off a mini moto which is the same material. Boiled it up on the hob and used the white wash and black. Didnt even touch it. Worked well on the swing arm chain roller though.
I have dipped a dirt bike tank and to my knowledge it is holding up well.  I could do that tank in any pattern for $200 so it is a pricey option.
That's a shame I was thinking of dying my tank covers and rad cover black
It might work for that as is probably a different kind of plastic. Some types will dye and some wont so its worth a try.
is that a natural tank...is all the discolour on the outside? or is that inside fuel stain showing through
Its all the same colour pretty much inside and out. Its just the natural crappy plastic colour i think.
