FYI Precision Powersports will put windows in stock cases so that you can change the shift forks on the rear transmission shaft. They also added another small modification to the shift fork shaft that makes it much easier. The mod would be useful on the billet cases as well, which is how I got the idea for the modded shaft.
that might not be a good sign.. lol   But cool mod none the less!  I'm interested!    Got a set of cases sitting here that I need done up..  I'll have to get with them and check on it.
"We guarantee you have never seen a quick change shift fork window in stock Yamaha Banshee cases...until now! Precision Powersports shift fork windows are sure to turn changing shift forks from a 4 hour job down to a 20 minute job. Send in your motor or lower case today!"
I've seen this done by GT years back but he never marketed it. The boys at PPS are definitely capable of getting the job done. This should be a good selling setup!
Sent from my SCH-I545 using Tapatalk
It is a super cool mod. I thought about doing mine but doubt I would for $300. If you guys would run duneables and balance the pressure on the springs so the sliders would clear each other you wouldnt go thru so many forks. If you dont balance the springs you dont have a duneable.
yup.  duneables should have this done because of the wear..  so called balanced springs or not  it will have pressure pushing the fork against the gear at all times..  they eat forks constantly
this is also great for bikes that have tuning problems and stutter in lower gears and trash shift forks..  or from bad riders and crap overrides that need forks installed often..
nice work!
