If you have the old boot can you see if there is a number on it? I think chariot sells all different genuine mikuni boots. Maybe Sudco to. I remember seeing some distributor that had replacements for almost any application.
 I run Mikuni VM34-200 boots on my Boss intake with 33PWK's. I believe you need Mikuni VM36-200 if your running a 36-38mm carb.
Ebay has both sizes for around $20 each and free shipping.
Edited by jbooker82
Well you could have a couple different options if your running larger 36-40mm carbs. One has a 70mm spacing and the other has a 75mm bolt spacing.
The VM36-200k has a 70mm spacing and the VM38-200 have a 75mm spacing.
VM34-200 for 30-35mm PWK's has a 60mm spacing.
They are on page 225 in Sudco's online catalog.
Knock offs from ebay?
Go measure your bolt spread.
9.999 x out 10 you will need the 60mm ones for your carb size and alike. The 70's are for the bigger junk.
Those are genuine in the link i posted.
