trickedcarbine Posted February 14, 2014 Report Posted February 14, 2014 30 pilots 440 mains to start with needle clip in the middle air screw 2 turns out. IMO those carbs are too small. Soak the carbs in some gas to clean them for a day/night A bad stator will ONLY show its issue under load. Revving it is not under load. Check it with an ohm meter. Your clymer book has the specs. Sent from my iPhone using Tapatalk Both horrendous pieces of information. 440 main? And on Mikunis you really should be using a different pilot if you need to be 2 full turns out. If you want your carbs cleaned, fucking clean them. Soaking them in gas isn't gonna fix the fact that gas has been soaking in them since they were manufactured and the bike's tank topped off. The. You say a bad stator only shows it's messed up under load, but to check it with a meter? So do I ohm it while I have it "under load"? Pretty conflicting and not the only way stators go bad. Quote
sprinklerman Posted February 14, 2014 Report Posted February 14, 2014 Both horrendous pieces of information. 440 main? And on Mikunis you really should be using a different pilot if you need to be 2 full turns out. If you want your carbs cleaned, fucking clean them. Soaking them in gas isn't gonna fix the fact that gas has been soaking in them since they were manufactured and the bike's tank topped off. The. You say a bad stator only shows it's messed up under load, but to check it with a meter? So do I ohm it while I have it "under load"? Pretty conflicting and not the only way stators go bad. Man. I'm glad YOU took the time to handle that. I'm too lazy. Sent from a van down by the river Quote
03DMshee Posted February 14, 2014 Report Posted February 14, 2014 440 main? Maybe he rides in -75 degrees? Quote
Nightmare Posted February 14, 2014 Report Posted February 14, 2014 I think Tony is too stony. Sent from my XT1080 using Tapatalk Quote
Deadbeat Posted February 14, 2014 Report Posted February 14, 2014 !paaaarB http://www.youtube.com/watch?v=m8StmcJNirw 1 Quote
sleeper06 Posted February 14, 2014 Report Posted February 14, 2014 Im suprised he didnt say ftw 420 mains on everything Quote
