If you Havnt been tig welding your self for years on aluminum, it's cheaper to just find another set of cases. But the more important thing to know is why the cases cracked. Was it a boulder or is the tranny wanting out?
If the crack is in the trans housing from chain whack I've repaired the leak with Toyota FIPG black. Just clean crack and case with brake clean to get all the oil out and off the crack. Then pack the crack from the inside with FIPG with your finger it will come out to the outside of case. Then I smooth a 1/4" thick cover of FIPG over the top of the crack inside the trans. Clean outside off so looks good it will never leak again as long as you don't chain whack it again.
