arielblazed94 Posted January 19, 2014 Report Posted January 19, 2014 Ok so i noticed a crack on the crankcase about 2 inches in length on the transmission side, it leaks oil. i wanted to know what is my best bet to use jb weld or have it welded ? Thank You. Quote
Nieskes Posted January 19, 2014 Report Posted January 19, 2014 How does it look from the inside? Got any pics? Quote
Surfrjag Posted January 19, 2014 Report Posted January 19, 2014 If its structural i would weld it or get a new set.. Quote
LCW Posted January 20, 2014 Report Posted January 20, 2014 I would weld it, but that may cost more than a good used set, unless you can tig cast yourself. Quote
trickedcarbine Posted January 20, 2014 Report Posted January 20, 2014 If you Havnt been tig welding your self for years on aluminum, it's cheaper to just find another set of cases. But the more important thing to know is why the cases cracked. Was it a boulder or is the tranny wanting out? Quote
monster Posted January 20, 2014 Report Posted January 20, 2014 If the crack is in the trans housing from chain whack I've repaired the leak with Toyota FIPG black. Just clean crack and case with brake clean to get all the oil out and off the crack. Then pack the crack from the inside with FIPG with your finger it will come out to the outside of case. Then I smooth a 1/4" thick cover of FIPG over the top of the crack inside the trans. Clean outside off so looks good it will never leak again as long as you don't chain whack it again. Quote
trickedcarbine Posted January 20, 2014 Report Posted January 20, 2014 Tdr sells the Toyota goo. Quote
