What are you going to use machine it? If you think you're going to do it with a sawzall and a dremel, you're in for a surprise.
Metal band saws do a nice job on thick heavy plates of polymer materials.
  • 2 weeks later...
Delrin isnt cheap if you buy a large chunk of it with the intent to make numerous parts.
A 1inch thick 12x12 sheet is approx $140.00 and you can get about 6 modquad style case savers from it. Modquad style is 7.5 inches tall and 3.5-4 inches wide. If you're creative, you can offset the pattern and get 2 savers for every 1/3 of the sheet.
Cotton branch uses about a 8 inch tall 7 inch wide piece. Add up the cost of a sheet and labor and you're pretty much seeing why he charges over 100.00 for it.
Prices are retail. And I'm on pain meds. Good day
Damn I run a billet one too.  I only run a 4 il cub, should I still change it out?
I saw the picture, but really, is there any guarantee that any case saver will save your case if you neglect your chain?
Edited by Justintoxicated
  • 2 weeks later...
B.b.p builders, on 02 Jan 2014 - 09:57 AM, said:
I can kinda understand the price more now, that delrin material isn't cheap. Then you need to make the actual case saver. 100$ is still to much $ in my eyes.
Let me know how that works out for you. If you can cut a nicer piece for less money, I'll be the first guy to buy one..
