  • Replies 54
  • Created
  • Last Reply
Top Posters In This Topic
You can make a leak down tester for cheap. A seal kit is also about $50 or close to it. I forget the actual price. So for under $125 you can have new seals and proof you engine doesnt have an air leak.An air leak can even be something as simple as a tiny leak by the reeds or carbs. The price of a new seal kit and leak down tester is than a motor going lean or stress cause by you not being able to figure out why you are having issues jetting it correctly or it running right.
Do it right. Youll thank yourself later.
  • 2 weeks later...
