salmon_slayer06 Posted August 8, 2013 Report Posted August 8, 2013 (edited) Anyone have experience using this stuff? I think it should be the easiest stuff to get a hold of since there is an auto-zone or O'reillys on every corner by me. I plan on using this on my case halves. If not what Yamabond or what three bond is the one I need or most used? Thank you... Edited August 8, 2013 by salmon_slayer06 Quote
salmon_slayer06 Posted August 8, 2013 Author Report Posted August 8, 2013 BTW... doing a 4mm build. Went through FAST and had my cylinders ported. I went with the dune/play port. I did get my cylinders back, and the workmanship can't be any better. They are a mirror image of eachother. I don't know how they do it, glad I chose them. Coolhead, domes on the way from them as well. Quote
Coupelx Posted August 8, 2013 Report Posted August 8, 2013 I bought a tube awhile back out of curiosity. Seems like decent stuff. Quote
jbooker82 Posted August 8, 2013 Report Posted August 8, 2013 That is what it is designed for. Way better than using RTV or Ultra Copper / Black. Quote
possum Posted August 8, 2013 Report Posted August 8, 2013 Its real stringy and sticky and dries really fast. I didnt like it. I dont like 1211 either tho. I went back to grey permatex. Quote
BANSHEE HP Posted August 8, 2013 Report Posted August 8, 2013 permatex 51813 anarobic sealer > all the other crap Quote
camatv Posted August 8, 2013 Report Posted August 8, 2013 import grey. i have seen the "motoseal" but its 2 bucks more than import grey ( hondabond) i have ran that on every motor i have built in the last 13 years. its great stuff never a failure plus does not cost 25 bucks like that 111212112221212121 crap yamabond black and grey are both stringy and slopy crap compared to the import ( honda style ) sealer. Quote
toytech Posted August 8, 2013 Report Posted August 8, 2013 Toyota oil pan sealer works great, but it's black so you have to clean off the excess on the outside. Quote
trickedcarbine Posted August 10, 2013 Report Posted August 10, 2013 Toyota oil pan sealer works great, but it's black so you have to clean off the excess on the outside.Tony at TDR put me on to that stuff. Freaking awesome! (Toyota seal packing) Quote
salmon_slayer06 Posted August 10, 2013 Author Report Posted August 10, 2013 thanks for the info. Looked into all the different kinds. Honda Bond sounds like it will be easier to use and have longer set time. The permatex stuff sounds like a possibility cause its easy to get. Anyone else use the permatex ultra gray? How is it? Quote
sheerider11 Posted August 10, 2013 Report Posted August 10, 2013 thanks for the info. Looked into all the different kinds. Honda Bond sounds like it will be easier to use and have longer set time. The permatex stuff sounds like a possibility cause its easy to get. Anyone else use the permatex ultra gray? How is it?Never had an issue. Have about 4 motors using it. Easily accessible. Walmart - autozone. Can get it anywhere Quote
Coupelx Posted August 10, 2013 Report Posted August 10, 2013 In reality the list of what not to use is shorter, The red or blue shit that you used instead of gaskets on your inbred buddies chevy? Yea leave that shit in the trash. The clear shit you sealed your bath tub up with? Save it for your bathroom. Probably a few others too. I wouldnt use anything that dries hard either if you ever want to take it apart. Quote
Bad one ton Posted August 10, 2013 Report Posted August 10, 2013 So liquid nail is a no go? Lmao. I like that 1211 shit. Its pricey but works well. TON! Sent from my iPhone using Tapatalk Quote
