Spanks906 Posted July 21, 2013 Report Posted July 21, 2013 Opinions? Looking at elka or works for shocks. No clue on a arms. I mainly ride trails (fast). They are old railroad grades. Bike is blue/gray plastics with a blue/black frame. Thanks, Brad. Quote
sheerider11 Posted July 21, 2013 Report Posted July 21, 2013 A arm-Roll design, houser, Walsh, leager, LSR Shocks-Custom axis, fox float x evols, Elka stage 5 Quote
Spanks906 Posted July 21, 2013 Author Report Posted July 21, 2013 Any of the a arm kits better than others for alignment purposes? $1800 for a set of stage 5s seems high. How's the factory rear shock? Quote
sheerider11 Posted July 21, 2013 Report Posted July 21, 2013 This just poped up in the FS http://bansheehq.com/forums/index.php?showtopic=168803#entry1504515 you'd be stupid to not buy this set up Quote
sheerider11 Posted July 21, 2013 Report Posted July 21, 2013 The factory rear after a little attention is half decent. Talk to Matt at SCSS. I'm waiting in some to come back from him. Quote
4psnu Posted July 21, 2013 Report Posted July 21, 2013 Lone star A arms and PEP shocks!!! Any thing else and you are wasting your money!!! Quote
Spanks906 Posted July 21, 2013 Author Report Posted July 21, 2013 A arm-Roll design, houser, Walsh, leager, LSR Shocks-Custom axis, fox float x evols, Elka stage 5 Flot Evol x over the podium x? I know the floats run great on my sled. Do they make the float evol x in the 13.75 stock length or do I need to do a long travel front end? I am going to have the rear shock revalverevolved as I can't afford the whole set at once. First is going to be front shocks and then second round ia front end and rear shock. Quote
Nightmare Posted July 21, 2013 Report Posted July 21, 2013 Axis FTW Sent from my SGH-T679 using Tapatalk 2 Quote
So Cal Suspension Posted July 21, 2013 Report Posted July 21, 2013 Definitely Custom Axis shocks. Lonestar or Laegars for arms. If you ride trails, and they get narrow at times, I would keep in mind your width when ordering arms. Quote
Spanks906 Posted July 21, 2013 Author Report Posted July 21, 2013 Definitely Custom Axis shocks. Lonestar or Laegars for arms. If you ride trails, and they get narrow at times, I would keep in mind your width when ordering arms. The +2+1 would work since I'm running 20x11x9 rear tires and they stick out much further than my fronts. Matt, you sell axis and lonestars? Also do you recommend long travel? I don't mx or jump much at all. Quote
So Cal Suspension Posted July 21, 2013 Report Posted July 21, 2013 The +2+1 would work since I'm running 20x11x9 rear tires and they stick out much further than my fronts. Matt, you sell axis and lonestars? Also do you recommend long travel? I don't mx or jump much at all. No, I don't retail any suspension other than JL Engineering. Too much of a hassle for what little bit of business I do in the ATV industry. If you can afford the LT arms, go for it. The shocks will be the same price as standard travel. That's the only part that will be more expensive. Quote
Spanks906 Posted July 21, 2013 Author Report Posted July 21, 2013 Which shocks do you recommend from them? I was looking at the cross country shocks with dual rate springs, high/low speed compression. I want to get the plush ride kit. Opinions? 1 Quote
So Cal Suspension Posted July 22, 2013 Report Posted July 22, 2013 Which shocks do you recommend from them? I was looking at the cross country shocks with dual rate springs, high/low speed compression. I want to get the plush ride kit. Opinions? Get the best your budget will allow. Quote
Spanks906 Posted July 22, 2013 Author Report Posted July 22, 2013 Get the best your budget will allow. The ones I'm referring to are $1700/pair. Air or coil spring?????? I'm new to tbe suspension market. Quote
So Cal Suspension Posted July 22, 2013 Report Posted July 22, 2013 The ones I'm referring to are $1700/pair. Air or coil spring?????? I'm new to tbe suspension market. I prefer coil springs on everything. I'm not a fan of air springs whatsoever, in any application, other than standard fox floats on a drag bike. Quote
