hoot Posted June 25, 2013 Report Posted June 25, 2013 Alright,I ordered the kit from fast and when I put it on the bike there is a ton of slack in the cable and the adjusters are all the way out.The slides are maybe opening about half way.also the throttle doesn't even pull till about half throttle.what am i doing wrong.Thanks for the help Quote
sheerider11 Posted June 25, 2013 Report Posted June 25, 2013 Did you get a twist throttle cable? Quote
hoppedupandcutdown Posted June 25, 2013 Report Posted June 25, 2013 Do you have a twist throttle with a thumb throttle cable? or vice-versa? Quote
hoot Posted June 25, 2013 Author Report Posted June 25, 2013 i have the thumb throttle but the sent the twist cables,called them and they said they would work Im guessing they wont. Quote
oldskool Posted June 25, 2013 Report Posted June 25, 2013 I'm thinking thumb throttle and twist are two different cables. Almost positive Quote
hoot Posted June 25, 2013 Author Report Posted June 25, 2013 can someone please confirm this,when I called fast they said it will work. Quote
2strokeshees Posted June 25, 2013 Report Posted June 25, 2013 Im pretty sure they are different, when I bought mine they sent the twist cable, I don't remember the company but they sent out a thumb cable free of charge and it worked perfect. Quote
sheerider11 Posted June 25, 2013 Report Posted June 25, 2013 They are 100% different. The twist is 3/4-1 inch longer. Quote
Spanks906 Posted June 25, 2013 Report Posted June 25, 2013 I'm in the same boat, ordered kit from fast and the cable is too long. Thanks for the help! Quote
d4n1932 Posted June 27, 2013 Report Posted June 27, 2013 I want to change my with the kit, does not sound like I should order from fast. Quote
Spanks906 Posted June 27, 2013 Report Posted June 27, 2013 I want to change my with the kit, does not sound like I should order from fast. Ok, so a little clarification. Hoot and I are both working on our Shee's. We thought since my cable was TOO LONG that the other one I had and the one he had was. Well.......................The other two were correct. DO NOT BE DISCOURAGED when ordering from fast, when I had an issue with a spring (got sent 5 light and 1 heavy) he fixed the issue the next day no problem or questions asked. Again, 2 cables were right, one wrong. They all said the same part # on the bag, but the cables themselves were different numbers. Hope this helps............ Thanks, Brad. Quote
