dune goon Posted April 13, 2013 Report Posted April 13, 2013 so as you guy mught have realized I ask something stupid or have a problem i post about the bike almost daly, anyway the problem now is the banshee seemed extremly slugish and slobbery so i did a plug change the ones i took out were very old. anyways cleaned up idle and midrange alot but now i have realized what the real problem is, ignition just as the bike enters the power band it just stops revving, acts like when your riding one that is too cold that wont rev, anyways Im about to send this turd down the road im so mad at it. do any of you guys have a similar problem or know what it is? thanks - Zack Quote
Surfrjag Posted April 13, 2013 Report Posted April 13, 2013 could be a few things but first check the stator and pickup. is it oem or aftermarket? Quote
Larry's Shee Posted April 13, 2013 Report Posted April 13, 2013 Are you sure jetting is good? Maybe post modjetting, elev. Check all connections are clean and tight. Ohm ALL components. Coil mount clean, bare metal or run seperate ground. Quote
dune goon Posted April 13, 2013 Author Report Posted April 13, 2013 okay yes jetting and mechanical crap is perfect its deffinatly electrical and as of oem or aftermarket stator i dont have the slightest clue Quote
Jereme6655 Posted April 13, 2013 Report Posted April 13, 2013 if your sending it down the road......send it in my direction.....ill MAKE a spot for it in my garage haha Quote
blue angel Posted April 13, 2013 Report Posted April 13, 2013 I will give you $1 more than Jereme. Quote
noonansar Posted April 13, 2013 Report Posted April 13, 2013 I had a weak stator and my shee wouldnt start. Still had spark that looked decent, just wouldnt start. Changed the stator and it runs perfect. Seems like if it was ignition the bike would start hard or run rough throughout. Are you sure its not a mechanical carb issue or poor jetting? have you cleaned the air filter? Quote
notsed Posted April 13, 2013 Report Posted April 13, 2013 probably the stator, id see if you could get one to try out Quote
bansheesandrider Posted April 13, 2013 Report Posted April 13, 2013 Sounds to me like the main jet is off, it is acting up right when the main jet comes into play. You need to post up ALL of your mods and EVERY thing we need to know about your setup and riding location,style and elevation. You also need to verify the manufacturer of your flywheel, stator, CDI box and coil and make sure you have good clean connections at ALL of your grounds. Quote
bansheesandrider Posted April 13, 2013 Report Posted April 13, 2013 Look on the web for pictures of the various brands of stators, etc. Quote
