I have never heard of engine ice being a bad coolant to use. Im not positive if it can be used below freezing however. I have been recommended it numerous times and going to grab some.
ok thanks cause I just wanted to know about other people opinions and see if it would even out on a poll vote topic!
toyota longlife coolant, b cool coolant, honda coolant, they all a great coolants that do not have the silicates in them to to sand bast the waterpump impeller.
there are others too.
Thanks guys this some real good info. But if I wanted to use regular anti-freeze , at 70 degrees and up use srt8 full strength Anti-freeze .
An when its 60 degrees or lower I can 50/50 anti-freeze right?
you should always use 50/50 unless the antifreeze comes premixed,
Ive heard this before my several people. What are the benefits of running 50/50 vs straight?
strait coolant does not cool as good, it doesn't transfer the heat as good it is designed to mix.
Just so ya know. Don't put to much thought into it. All anti freeze does is not let the water freeze. It's the water that cools your engine. You can run straight water in te summer time if you wanted. Keep it simple dude
