Justintoxicated Posted October 18, 2003 Report Posted October 18, 2003 I pulled the top end off my 4 year old shee, I think it looked pretty good except for this black stuff? You tell me. Ok, so a couple questions, 1) What the hell is the black crap on my reeds, 2) Why is are the piston arms different colors? Quote
Leadfoot350 Posted October 18, 2003 Report Posted October 18, 2003 I would have to say paint that yamaha puts on the cylinders that some how got on the reeds. As far as the rods mine were the same way too. Quote
Justintoxicated Posted October 18, 2003 Author Report Posted October 18, 2003 I also find a small ding in the top of one of the domes. WOuld that hurt performance? I think it looks good for being 4 years old, minus the paint thing and the small ding in the top of the dome... Ill post a picture, but is the head still any good? Quote
. Posted October 18, 2003 Report Posted October 18, 2003 try scraping some off the reed stops. If it flakes off like paint would chances are its paint. It could also be the gasket sealer they used when putting the intake gaskets on and got a little generous? Get some dual stage reeds when you throw that thing back together and ditch those reed stops. Your throttle response gains will be enormous. Quote
00BANSHEE Posted October 18, 2003 Report Posted October 18, 2003 What kind of oil premix do you run? Not much carbon buildup on the pistons. Quote
Justintoxicated Posted October 18, 2003 Author Report Posted October 18, 2003 how much are good reeds? Or do I just need reed stops? How much? It does appear to be paint, yamaha seems to have used white gasket sealer (Lithium grease?) What will I need for sealer when I put it back togther? The oil I have been using is YamaLube, mixed just a little over 32 to 1. I guess I could have just put in new rings and pistons. But porting will be much better anyways. Quote
. Posted October 19, 2003 Report Posted October 19, 2003 good reeds will run you about 40 bucks. Well worth the money. You could use yamabond if you want to attach the gaskets to the jugs. I dont know what others use if anything at all, but I would think it would be something to use. Mine were pretty stuck to my jugs, figured they used a sealer of some sort. Get some boyeson dual stage reeds. I prefer them over the carbon fibers. Dont think they flex enough and if you happen to break one they arent going to burn up in your cylinders as easily as a regular reed. Quote
chase73 Posted October 29, 2003 Report Posted October 29, 2003 ? why did you take the top end apart it does not look bad at all. Did u do a comp test and dicide to do top end ???? The black stuff is just paint like everyone has said no worries at all. I was just asking because after 4 years off riding it if it aint broken dont fix it Quote
Justintoxicated Posted October 29, 2003 Author Report Posted October 29, 2003 ? why did you take the top end apart it does not look bad at all. Did u do a comp test and dicide to do top end ???? The black stuff is just paint like everyone has said no worries at all. I was just asking because after 4 years off riding it if it aint broken dont fix it I did a comprression test 105/115 , and I noticed some loss n HP right before I decided to get it ported Quote
itsaripper Posted October 30, 2003 Report Posted October 30, 2003 Doesn"t that guys arm get tired? Get some TDR .018 and port the cages. They are about $33 shipped. Keep the stops. They will keep the peddles from fluttering and then cracking. A couple of little dings in the head won't hurt performance. Can you smooth them out? I have seen some heads that looked like a little kid with a new hammer was practicing on the squish band. Quote
