I picked up a set of cylinders real cheap n found that they were ported. I have no idea to tell what type of port this is or if bad port job. Any help would be great. Sure. I could just put em on and see but I can't ride where I'm at and its over 2 hrs away. Thanks
Measure from the deck to a roof of exhaust port. If it is rised alot and those transfers are stock duration, it might have good pull up top, but not much bottom end power.
The work is definitely just some Joe in his own garage. Although not pretty its not bad. Looks like he just tried to clean a few things up and knife edge the intakes and transfer tunnels. Good news, they aren't to far gone at all. You can definitely have a builder re work them if ever needed.
  • Like 1
