trickedcarbine Posted January 24, 2013 Report Posted January 24, 2013 Just had to be all different, huh Matt? The Bel Ray synthetics are great stuff though. I used it in my old KX 125 Quote
101Diesel Posted January 24, 2013 Report Posted January 24, 2013 Just switched to Super Techniplate because of going to alky. R-50 and Motul 800 2T are excellent synthetics too... Quote
turbowrenchhead Posted January 24, 2013 Author Report Posted January 24, 2013 I'm surprised that no one has said Super M. The guy who built my blaster motor swears by the stuff. And its a little cheaper then the other oils mentioned. http://www.ebay.com/itm/Maxima-64-oz-Super-M-2-Cycle-Oil-/390474337332?pt=Motorcycles_Parts_Accessories&hash=item5aea158c34&vxp=mtr Quote
turbowrenchhead Posted January 24, 2013 Author Report Posted January 24, 2013 Here is a great deal on Lucas semi synthetic. http://www.ebay.com/itm/370734345730?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 Quote
dajogejr Posted January 24, 2013 Report Posted January 24, 2013 Maxima castor 927 if it's warmer, but for ice season I run the Amsoil Dominator to ecause the castor stuff of any brand will separate at freezing temps. It may separate if left sitting for periods of time. But if you ask any of the drag race guys that run methanol and castor (have to run castor, won't mix at all otherwise) it stays blended just fine. So if you leave fuel in the tank, shake it up before use...same as fuel in the gas can. That's a disclaimer because eventually it will separate....but if used properly, it'll work just fine. Promise... Quote
PassionRE Posted January 24, 2013 Report Posted January 24, 2013 927 hands down, especially on methanol. Quote
trickedcarbine Posted January 24, 2013 Report Posted January 24, 2013 It may separate if left sitting for periods of time. But if you ask any of the drag race guys that run methanol and castor (have to run castor, won't mix at all otherwise) it stays blended just fine. So if you leave fuel in the tank, shake it up before use...same as fuel in the gas can. That's a disclaimer because eventually it will separate....but if used properly, it'll work just fine. Promise... That's what I did to run out the C12 fuel I had but my last jug I just gave it the dominator. I always thought it should be fine, just to big of a pussy to keep testing my luck. Quote
01banch Posted February 13, 2013 Report Posted February 13, 2013 I've ran golden spectro in every 2 stroke I've owned to good effect. Quote
WaynokaBanshee Posted February 14, 2013 Report Posted February 14, 2013 Just don't use yamalube from what Jeff at fast said it isn't as good as klotz Quote
Nightmare Posted February 14, 2013 Report Posted February 14, 2013 Just don't use yamalube from what Jeff at fast said it isn't as good as klotz True, it's not as good as klotz but there's nothing wrong with it. I've been running in a stock bike for a long time with no problems. Sent from my SGH-T679 using Tapatalk 2 Quote
shustack Posted February 15, 2013 Report Posted February 15, 2013 Klotz Supertechplate @ 32:1 FTW! Quote
