I'm trying to decide on what pipes to go with. I am building a 421 with a clean up port job and I'm putting new plastics on, so i dont want pipes that wont fit with my front fenders. I was thinking about shearer pipes but they look to big for the fenders and i dont want them melting. suggestions definitely appreciated
Will Toomey T5's clear they fenders? I have fatty pipes now that came with the quad but i heard t5s are better than the fattys for mid to top end. im thinking t5s might be a little better than shearers for me to because im doing some woods riding.
Had to cut fenders back to make my old t5s fit, u doing a 421 serval?
If you take your time you can easily trim the inside of the fenders where the "bigger pipes" would hit! I trimmed my fenders to clear my shearer and you would of thought it was factory! Dont kill your motor build because of fucking fenders! Thats just dumb! Talk to a builder and get the pipe he recommends for your setup! Then just carefully trim the amount of fender that is needed to clear the pipes!
I bought a banshee off my friend that was in pieces because he bought an athena big bore kit and through it on not realizing the connecting rod bearing was bad. So now I have it lol :) since the crank is bad and the banshee is in pieces im redoing the whole thing and building a 421 with it using the athena cylinders
x100
Get a Dremel tool, very easy to do, just take your time.  You can make a radius edge that follows the contour of the pipe, when done
it almost looks factory.
