Z400Banshee Posted November 27, 2012 Report Posted November 27, 2012 I'm trying to decide on what pipes to go with. I am building a 421 with a clean up port job and I'm putting new plastics on, so i dont want pipes that wont fit with my front fenders. I was thinking about shearer pipes but they look to big for the fenders and i dont want them melting. suggestions definitely appreciated Quote
Z400Banshee Posted November 27, 2012 Author Report Posted November 27, 2012 Will Toomey T5's clear they fenders? I have fatty pipes now that came with the quad but i heard t5s are better than the fattys for mid to top end. im thinking t5s might be a little better than shearers for me to because im doing some woods riding. Quote
rjdgriff Posted November 27, 2012 Report Posted November 27, 2012 Will Toomey T5's clear they fenders? I have fatty pipes now that came with the quad but i heard t5s are better than the fattys for mid to top end. im thinking t5s might be a little better than shearers for me to because im doing some woods riding. Had to cut fenders back to make my old t5s fit, u doing a 421 serval? Quote
special06shee Posted November 27, 2012 Report Posted November 27, 2012 If you take your time you can easily trim the inside of the fenders where the "bigger pipes" would hit! I trimmed my fenders to clear my shearer and you would of thought it was factory! Dont kill your motor build because of fucking fenders! Thats just dumb! Talk to a builder and get the pipe he recommends for your setup! Then just carefully trim the amount of fender that is needed to clear the pipes! Quote
Z400Banshee Posted November 27, 2012 Author Report Posted November 27, 2012 Had to cut fenders back to make my old t5s fit, u doing a 421 serval? I bought a banshee off my friend that was in pieces because he bought an athena big bore kit and through it on not realizing the connecting rod bearing was bad. So now I have it lol since the crank is bad and the banshee is in pieces im redoing the whole thing and building a 421 with it using the athena cylinders Quote
bluebanshee98 Posted November 28, 2012 Report Posted November 28, 2012 If you take your time you can easily trim the inside of the fenders where the "bigger pipes" would hit! I trimmed my fenders to clear my shearer and you would of thought it was factory! Dont kill your motor build because of fucking fenders! Thats just dumb! Talk to a builder and get the pipe he recommends for your setup! Then just carefully trim the amount of fender that is needed to clear the pipes! x100 Quote
Banshee Chad Posted November 28, 2012 Report Posted November 28, 2012 I bought my 06 new. Trimmed the fenders just enough to keep a gap between them and the cpi pipes.. looks good, don't be scared of a little trim.. Quote
Z400Banshee Posted November 28, 2012 Author Report Posted November 28, 2012 thanks for the replies! I'll just do a little trim work on the fenders. just wondering what do you guys think about the trinity pipes compared to cpi or shearer Quote
So Cal Suspension Posted November 28, 2012 Report Posted November 28, 2012 Any porting on the cylinders? or as cast? Odds are the shearers are going to out perform anything else you throw on them. Quote
Z400Banshee Posted November 29, 2012 Author Report Posted November 29, 2012 just a clean up port and port matched case Quote
fastforworddad Posted December 6, 2012 Report Posted December 6, 2012 Get a Dremel tool, very easy to do, just take your time. You can make a radius edge that follows the contour of the pipe, when done it almost looks factory. Quote
