Z400Banshee
Everything posted by Z400Banshee
  1. Im doing a DC conversion on my banshee to run two 3x3 fans. I ordered a 7004-RR150 150 watt regulator from trail tech to run them and was wondering if i have to use a battery since they are just small fans
  2. Can I still use the stock lights if I do a DC conversion?
  3. Is it possible to power 2 small 12V DC fans without changing the stator and adding a battery. Heres the fans im trying to use. http://www.ebay.com/itm/80mm-25mm-New-Case-Fan-12V-Waterproof-IP55-43CFM-4-Screws-2-Pin-Ball-Brgs-395a-/170896629252?pt=US_Computer_Case_Fans&hash=item27ca3b9e04
  4. lol i dont hear many good things on here about the athenas but its want i have. i was going to use them on a 421 set up so i might get some better cylinders for the 421 How many jet sizes should i go up? The stock cylinders didnt have any porting done neither do the athenas
  5. I might be switching to atheans cylinder because my stock cylinder is cracked and i have the athenas sitting on a shelf. They are the big bore 392's so would i have to rejet since im only have 347cc with stock cylinders
  6. I was running a 2 piece but went to a 1 because I couldnt find a 2 piece in a .040. I think im going to try pulling the plugs and re-silicone them with a new gasket :/
  7. I got my base gasket on friday so I finished putting it all back together to find the base gasket leaking It was leaking coolant through it and looked and felt a little oily. I even siliconed the rubber plugs in. I guess im going to try a different gasket :/
  8. I can only find a 1 piece base gasket in .040 so i order it. Will a 1 piece gasket work on stock cylinders?
  9. Thats what im shooting for. I'm trying to figure out what size base gaskets I'm going to need. I think I'm going to need a .040 but im not sure. I'm also trying to figure out what is going on with my ports
  10. 513's came out and im pretty sure its a stock crank. heres another picture at TDC http://s466.beta.photobucket.com/user/shootemup1864/media/010_zps39433e7d.jpg.html
  11. I just finished putting my stock motor together and im using a cool head. when i was putting it back together i noticed that the pistons wouldnt drop flush with the transfer ports. the pistons are slightly blocking them. i wasnt sure if thats normal on a stock cylinder motor or not. Ill post some pics of it as well. Anyways I put that head and did a squish band test and came with about .025. I know im going to have to switch the base gasket size and that will also help with the ports but im not sure what size gaskets to get. I'm using .018 cometic gaskets right now. http://s466.beta.photobucket.com/user/shootemup1864/media/009_zps36302fe5.jpg.html?sort=3&o=0 http://s466.beta.photobucket.com/user/shootemup1864/media/008_zps093d5652.jpg.html?sort=3&o=1
  12. ok sorry you guys couldnt figure that one out lol
  13. take it you never heard the term bologna skins
  14. I ordered my +2+1 a-arms with stage 3 elkas front and rear. im going to be using 3/2 wheels but im also going to need new skins for the front and im looking for help picking out a good set for trails. Im thinking im going to be using ohtsu mr50 in rear
  15. 2nd question. someone suggested to leave the atheanas unported in my situation for a trail set up. would my port timing be messed up with them unported? I'm using blaster pistons with them
  16. about 35 yards it was getting dark so i was kinda in a hurry
  17. My buddy took a YFZ450 frame and put a YZ250 engine in it. http://s466.beta.photobucket.com/user/shootemup1864/media/103_zps34fbacb1.jpg.html?sort=3&o=0 http://s466.beta.photobucket.com/user/shootemup1864/media/102_zpscdb48970.jpg.html?sort=3&o=1
  18. I wanted there to be something left lol plus im not buying any 5.56 ammo right now with them at almost a dollar a round
  19. So today I decided to test out some old pistons I had laying around to see how "bulletproof" these were. I took out my LWRC M6A2 with my 22 conversion. Here are the results. The first 2 are the athenas http://s466.beta.photobucket.com/user/shootemup1864/media/098_zps0519b2db.jpg.html?sort=3&o=2 http://s466.beta.photobucket.com/user/shootemup1864/media/099_zps6c464ddd.jpg.html?sort=3&o=1 http://s466.beta.photobucket.com/user/shootemup1864/media/100_zps287c74c9.jpg.html?sort=3&o=0
  20. I have some atheana cylinders that are 68mm so I am thinking about having rob port them but I saw some cub cylinders on ebay. I want a trail bike set up. What do you guys think a better choice would be. Having rod port the atheana's or getting these stage 2 ported cubs? http://www.ebay.com/itm/Banshee-RZ350-421cc-68mm-Ported-Cheetah-Cub-Cylinder-/350325403705?pt=Motors_ATV_Parts_Accessories&hash=item5191057039&vxp=mtr
  21. I didn't get the arms yet so im still up for suggestions on them. If I did the +3 arms with 4/1 offset would they be about the same width as runnig +2 arms with the 3/2 offset?
  22. I ride a lot of trails so I'm getting +2+1 lonestar A-arms with stage 3 elka suspension. I'm going to be getting new wheels for it but I dont know what wheel offset I should go with. Whats the advantages and disadvantages of 4+1? Same thing on the 3+2 advantage and disadvantages.
  23. thanks for the replies i thnk im going to shoot for a 9 then and go with 20x11x9 tires
  24. lol no ill keep it myself for that price
