gwinnraptor Posted September 26, 2012 Report Posted September 26, 2012 I have a stock motor with pro design intake and pro circuit exhaust. This is the first banshee i have owned, and all these parts came on it....so i have no experiences with anything else. Just wondering how this exhaust compares on stockish motors vs other exhausts. Is this a good exhaust to be running with a stock motor? I ride mainly open fast trails and fire roads. I ran a few searches and didnt turn up anything. Quote
Dicklez Posted September 26, 2012 Report Posted September 26, 2012 The Paul circuits are aight. Quote
fuller1986 Posted September 26, 2012 Report Posted September 26, 2012 For trails and fire roads which is what I ride the pro circuits are a great low and mid pipe not sure on the intake I run a 2 into 1 but I have just a stock bore build and it pulls like a bitch so unless u want more top end for the build you have the pc's are a good pipe. Quote
toytech Posted September 26, 2012 Report Posted September 26, 2012 on a stock motor, pc,fmf,toomey,paul turner. are all great pipes. Quote
Colby Posted September 26, 2012 Report Posted September 26, 2012 best pipe for unported motors is Toomey T-6 Quote
Finch Posted September 26, 2012 Report Posted September 26, 2012 t-5s worked great on my stockers and then when ya decide to port (which you will its inevitable) youll already have a good pipe Quote
MarineNYC Posted September 26, 2012 Report Posted September 26, 2012 DMC!! Find a you setup for around 300 bucks for and you will not be disappointed. Quote
Nieskes Posted September 26, 2012 Report Posted September 26, 2012 I ran fmf's for a long time an loved them! Quote
ATVridinMaNiAc Posted September 26, 2012 Report Posted September 26, 2012 Probably T-6s from what ive heard, mine has them and my bike is pretty much stock internals, stock head and its surprisingly quick alot of people think it has way more done to it and i believe its mostly because the pipes are perfect for a stockish bike without porting, higher comp and stuff. Quote
Bad one ton Posted September 26, 2012 Report Posted September 26, 2012 The problem with the t-6 pipes is there good for a stock motor, if you ever decide to port it you will be held back by them. Id stay with your pc's. There a good low/mid pipe which from the sound of it is what you want for the terrain your in. There good pipes. TON! Sent from my iPhone using Tapatalk Quote
Nightmare Posted September 26, 2012 Report Posted September 26, 2012 I think t5's are still better for a stock engine than 6's imo. Sent from my SGH-T679 using Tapatalk 2 Quote
Glenyboy Posted September 26, 2012 Report Posted September 26, 2012 Keep what you have for what difference there may be between trial pipes, just invest in some aftermarket suspension if you haven't already. Quote
gwinnraptor Posted September 26, 2012 Author Report Posted September 26, 2012 alright, thanks guys. Ill just stick with my Pro Circuits....maybe just do some porting down the road. As for updated suspension its decent, shocks need to be revalved for my weight. I have +2/+1 lonestar arms with works shocks....not the best shocks but way better than stock. The rear shock is stock with a lonestar +4 axle. I am happy with the way it rides except for the soft front shocks. Quote
Uf21 Posted September 27, 2012 Report Posted September 27, 2012 DMC 916, Sounds AMAZING. it beats my mates toomey t5's and t6's also has better bottom end power over the toomeys. I also ride open and fire trails. Quote
