stand er up Posted September 16, 2012 Report Posted September 16, 2012 So i finally decided to go with a 4 mill build,going to use my stock cylinders with a port and a new cool head,anything else that is a must? Quote
nmdesertbansheeryder Posted September 16, 2012 Report Posted September 16, 2012 what kinda carbs and intakes and exhaust are you going with? Quote
dunesovertrails Posted September 16, 2012 Report Posted September 16, 2012 (edited) When i called Herr Jugs they said you dont need different carbs unless you want more topend and they said the fmf fattys i have would be just fine but others would work good to. I've heard shearers in frame sb with a 4 mil and it sounds amazing. If you got the money to get shearers. Edited September 16, 2012 by dunesovertrails Quote
toytech Posted September 16, 2012 Report Posted September 16, 2012 So i finally decided to go with a 4 mill build,going to use my stock cylinders with a port and a new cool head,anything else that is a must? what kind of riding? Quote
5150banshee Posted September 16, 2012 Report Posted September 16, 2012 I would definitely go with boss intakes no cross over and bigger carbs, I wet 4 mil and used stock the first ride and didn't like it so came home threw some 35 pwk's on and also the boss one piece intake and it really came to life. Although this may add an additional 4-5 to the build for new parts u might be able to find them on here for Cheeper used. Good luck Sent from my iPhone using Tapatalk Quote
Nightmare Posted September 17, 2012 Report Posted September 17, 2012 aftermarket impeller. I never seen the stocker fail but gives u piece of mind IMO. Sent from my SGH-T679 using Tapatalk 2 Quote
dozer Posted September 17, 2012 Report Posted September 17, 2012 if you plan on running shearer sb inframes go with upp intakes, they have better clearance Quote
Infamous039 Posted September 17, 2012 Report Posted September 17, 2012 I have complete HJR 4mill package I will sale to you. Just sent you a PM Quote
n2otoofast4u Posted September 17, 2012 Report Posted September 17, 2012 My suggesion is buy my serval cyld Quote
