i have a 2000 and it has a boost bottle, i have heard to take it off and go with a stock crossover, then do a plug chop. what is a plug chop and what are the benefits or why should it be done...stock cylinders and power reeds, dunno if that matters or not.....confused..thanks for any help
you do a wide open run 1-6 gear pullin the clutch kill it coast to a stop. chop off the threads on the plug looking for a nice 2mm brown ring at the base. but waste of a plug but good way to check jetting if no good at just looking at plugs or by feel.
warm bike up......pull old plugs out and pu tin NEW plugs. then fire it up nd hammer it from 1-6th. when you hit the top of 6th pull clutch like stated earlier and kill engine and coast to stop. remove those plugs and put original plugs back in it and ride back to your shop. then cut the threads off of the test plugs.
  • 2 weeks later...
thanks you very much
  • 1 month later...
