BAMF87 Posted August 26, 2012 Report Share Posted August 26, 2012 Hi, I have a 97 banshee that I just fully rebuilt and powdercoated and everything. Took the engine apart and replaced crank seals and put all new gaskets everywhere. I've only had it out twice since the build and somehow riding "topped out" one of the spark plug boots came off and the it flat out died. When I stopped coolant was coming out of the case where the trans sprocket is on left side, also when I pulled my carbs off I can see coolant on my reeds. Any idea what may have happened. I'm hoping its just the cylinder gaskets. Quote Link to comment Share on other sites More sharing options...
Finch Posted August 26, 2012 Report Share Posted August 26, 2012 no coolant should be coming from base gasket unless one of your plugs is bad my guess is leaking in between the cases only way i know how it could get in ur tranny and your motor. Quote Link to comment Share on other sites More sharing options...
BAMF87 Posted August 26, 2012 Author Report Share Posted August 26, 2012 So you think Ill need to split the cases again and re seal them? Quote Link to comment Share on other sites More sharing options...
Finch Posted August 26, 2012 Report Share Posted August 26, 2012 if ya have it in your tranny and your cyl i cant think of anywhere else it would of came threw. but kind of odd its leaking into both but better safe then sorry water in crank makes for a s shaped od Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted August 26, 2012 Report Share Posted August 26, 2012 Check the tube that comes down the back of your head, and the solid coolant tube where it goes into your clutch cover. I bet you have a bad or pinched coolant tube oring and the coolant is just seeping out and going across the top of your cases. Quote Link to comment Share on other sites More sharing options...
BAMF87 Posted August 26, 2012 Author Report Share Posted August 26, 2012 Thx ill check that, but it was like squirting out of the area that the tranny sprocket stick out, like it pressured up Quote Link to comment Share on other sites More sharing options...
007banshee Posted August 26, 2012 Report Share Posted August 26, 2012 Thx ill check that, but it was like squirting out of the area that the tranny sprocket stick out, like it pressured up Do you have the hose connected to the nipple near the rear motor mount, anything coming out of that hose? Quote Link to comment Share on other sites More sharing options...
BAMF87 Posted August 26, 2012 Author Report Share Posted August 26, 2012 U mean the hose with the plastic end on it that pops into the case by the rear mounts? It's connected not sure if it leaked there ill check when I get home Quote Link to comment Share on other sites More sharing options...
Rotax Raptor Posted August 26, 2012 Report Share Posted August 26, 2012 What about the water pump seal. That may where the pressure and anti freeze is coming from. Quote Link to comment Share on other sites More sharing options...
Finch Posted August 26, 2012 Report Share Posted August 26, 2012 What about the water pump seal. That may where the pressure and anti freeze is coming from. still doesnt explain it in the cyls Quote Link to comment Share on other sites More sharing options...
BAMF87 Posted August 26, 2012 Author Report Share Posted August 26, 2012 Thx for the fast replies guys due to work it'll be a few days before I can work on it good. I'll advise what I find out. Quote Link to comment Share on other sites More sharing options...
BAMF87 Posted August 29, 2012 Author Report Share Posted August 29, 2012 Ok looked at the bike closer and no coolant in cylinders I guess the angle I was holding my light made the reeds look green. BUT the two plugs on the very bottom of the motor are, well.........gone! Where can I get new plugs for it. Quote Link to comment Share on other sites More sharing options...
Finch Posted August 29, 2012 Report Share Posted August 29, 2012 id hit up a builder or as a last result you could over pay at the stealership Quote Link to comment Share on other sites More sharing options...
BAMF87 Posted August 29, 2012 Author Report Share Posted August 29, 2012 What exactly are they called Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted August 29, 2012 Report Share Posted August 29, 2012 Are you talking about the very bottom of the cases? Or are you talking on the bottom of the cylinders? If your taking on the bottom of the motor your looking for motor braces.........if your talking on the bottom of the cylinders then you need water plugs which the site sponsors sell. Quote Link to comment Share on other sites More sharing options...
