JoeStar85 Posted May 6, 2012 Report Posted May 6, 2012 I need to purchase a clutch puller. where can i get one? Quote
stokes77 Posted May 7, 2012 Report Posted May 7, 2012 You mean a flywheel puller? Dont need any special tools to take the clutch out. Quote
SheeManWomenHater Posted May 7, 2012 Report Posted May 7, 2012 if you are talking about a flywheel puller, a site sponsor, Farmandsandtoys.com has them, and by the sounds of it you might wanna grab a clymer manual too. Quote
ticktock Posted May 7, 2012 Report Posted May 7, 2012 You can get them at a local cycle shop for 12-15 bucks. The risk clutch holder u can get on eBay or RMATV. You can also weld a steel rod on a steel dick and use that for a clutch tool. Dl a manual below. Adam Quote
locogato11283 Posted May 7, 2012 Report Posted May 7, 2012 Ummm, yeaaaaa... About that clutch pulller.. Ummm, noooooo... Quote
BigRed350x Posted May 7, 2012 Report Posted May 7, 2012 Ummm, yeaaaaa... About that clutch pulller.. Ummm, noooooo... LOL! Fail. Quote
JoeStar85 Posted May 7, 2012 Author Report Posted May 7, 2012 Motion Pro Clutch Holding Tool This is what i was looking for. I guess it's a holder and not a puller. Quote
DallasGDub Posted May 7, 2012 Report Posted May 7, 2012 What are you trying to do, maybe we can give you some better tips? Are you working with the clutch or the flywheel? On the clutch side, if you are needing to keep it from spinning while you work on it, you can simply wedge the gears or use this, http://www.harborfreight.com/2-piece-rubber-strap-wrench-set-94119.html Quote
JoeStar85 Posted May 7, 2012 Author Report Posted May 7, 2012 My 4 mil kit will be here in a day or two. Gotta tear the motor apart to install it Quote
dave5.0 Posted May 7, 2012 Report Posted May 7, 2012 You can also weld a steel rod on a steel dick Man where u get one of them? Quote
Nieskes Posted May 8, 2012 Report Posted May 8, 2012 rag in the gears and and impact for the nut, or just use an impact and hold the basket with your hand. Quote
