jayc Posted May 4, 2012 Report Posted May 4, 2012 Anyone try mixing a little nitro with meth? maybe 5% or 10% of nitro 50 VP Quote
ginger Posted May 4, 2012 Report Posted May 4, 2012 i have in 4 stroke applications, but never on a 2 stroke app. if you do, you will definatly need to rejet Quote
n2otoofast4u Posted May 4, 2012 Report Posted May 4, 2012 Go look in the drag section. This was covered in decent detail. Quote
BigRed350x Posted May 5, 2012 Report Posted May 5, 2012 Mix it at 50% and drop 10 main jet sizes and you are good to go. Truth. Quote
locogato11283 Posted May 5, 2012 Report Posted May 5, 2012 Mix it at 50% and drop 10 main jet sizes and you are good to go. Truth. Lean is mean!! Quote
RadarRacing Posted May 5, 2012 Report Posted May 5, 2012 It works quite well in nitro cars at 20-32% and the other part of nitro fuel is methanol. Nitro has a tendency to fire before any spark in most other applications unless the engine is built for it. If I were wanting to play with it I think I would have very loose squish clearance and fairly low compression and not mix it with gas , only alky/ methanol. I know a few guys that used it a few years ago and they gave it up. Mostly due to engine failures and piston siezures. Quote
