so i bought my banshee as a project for $1200 the kid said it needed a stator so i went for it. Well i got the new stator, and it runs, like shit. lol But i got it to run decent enough to take for a ride, so i took it out. But around one of the head studs, its leaking coolant. So thats probably why its running like hell. But i noticed that its dripping gas out of the vent line from the bottom of the carb, only when running also. Just for a background it has some no name pipes, and what look like FMF powercore I's, adj timing plate, trinity stage IV single carb kit, v force (3?) reeds, and a pro design cool head with 20cc domes. If anyone has any advice on what i should do next PLEASE speak up. <_<
Ditch the 2into1 carb kit and get a set of dual's like keihin 28's or 33 pwk's. Something like that. Single-carbs suck. For the mean-time the fuel coming out the line is from improper float height or your needle valve isn't closing properly. yank the carb and tear it all apart and clean the shit out of it. I would also yank the head and replace your o-rings. Both are easy jobs. Next thing would be to get it jetted right. the poor performance is probably due to crappy jetting on top of your other issues. make sure your timing plate is set at +4 for starters.
Jared
Jared
good info there.
what is the 2-1 setups good for?
also while on the 2-1 subject how are those pipes?
good info there.
I run a 2-1 Intake with a 33 pwk , and I love it . Simple to maintain . Yeah you sacrifice top end , but I ride the Dunes and Trails and it suffers no where . If I were you I'd keep the 2-1 .
I also have a Motofast 2-1 pipe , and It's perfect for where I ride , it has a nice low to mid range powerband , It falls off on the top end a bit , but I like that low to mid range power , makes it kinda 4 strokey , more predictable I guess you could say.
single carb and single pipe belong on a blaster, banshees are meant for 2 hence the twin cyls.
two carbs are easy to tune, just do some researce on here, sync is importent.
exactly. it is no harder to tune than 1 carb. couple extra steps? sure, but no harder.
that motofast pipe falls off on the top end more than a "bit" and duning is where you want some top end. :headbang:
If you have used a 1:2 carb kit and lost a lot of power,your doing it wrong. 2-4 more hp bottom end,2-4 less on top on the same port/pipe setup. It is a trail mod,not a drag/top end mod.
Edited by Burt Reynolds
Here are the charts from a crank dyno,not rear wheel. Shows gains in the low,and losses in the high,just like any trail mod or low end mod will do. Im not saying that a single carb will make your banshee lay golden eggs,im saying there are enough benefits to single that some of us trail guys prefer it.
Yamaha has been doing it right for a long time
2s, 2cyl, 2 carbs. Other than some half ass old ass snomobile, show proof of multi cyl 2s with single carbs. I'll go 5:1 on ANYTHING you can find :whoa:
Exactly. Another case of people reinventing the wheel. Race teams spend millions to get the Carb as close to the valve/cylinder as they can. Maybe there's something to it!
Well then i guess we should stick to the stock a arms/swinger/shocks/pipe/head/porting/colors/tires wheels chain ect... because if yamaha has been doing it that way since the dark ages they must be perfect for everyone in stock form.
Ill pay pal anyone 20 bucks if they can tell me any serious drawbacks to having a single carb on a TRAIL bike,as a TRAIL mod.
Cause it's gay as
http://content8.flixster.com/photo/12/98/53/12985342_ori.jpg&imgrefurl=http://www.rottentomatoes.com/celebrity/liberace/&h=460&w=345&sz=100&tbnid=nLGkBakQaHX40M:&tbnh=91&tbnw=68&zoom=1&docid=T09XmnCktLTdxM&hl=en&sa=X&ei=WQepT93_McPAtgfx2ZiiAg&ved=0CIUBEPUBMAQ&dur=4024http://content8.flixster.com/photo/12/98/53/12985342_ori.jpg'>http://www.google.com/imgres?imgurl=http://content8.flixster.com/photo/12/98/53/12985342_ori.jpg&imgrefurl=http://www.rottentomatoes.com/celebrity/liberace/&h=460&w=345&sz=100&tbnid=nLGkBakQaHX40M:&tbnh=91&tbnw=68&zoom=1&docid=T09XmnCktLTdxM&hl=en&sa=X&ei=WQepT93_McPAtgfx2ZiiAg&ved=0CIUBEPUBMAQ&dur=4024http://content8.flixster.com/photo/12/98/53/12985342_ori.jpg http://content8.flixster.com/photo/12/98/53/12985342_ori.jpg
Edited by Larry's Shee
