yamahaty
Everything posted by yamahaty
  1. Im not exactly sure the slides are smooth as can be. When im riding it i let off and it stays as if i was at 1/4 throttle and sometimes it will stick around 3/4 to full throttle and i just shut it off then i fire it back up and it will be ok till i let off the throotle again and it does the same. But like i said the carbs are spotless.
  2. HI guys please help me im going on a big 3 day ride in 2 weeks and my throttles are sticking. I have taken the carbs completely apart Two ties now and they still stick. Both carbs are completely spotless but i cant figure this out. Can it posibly be reed problems, Please help guys. Anything will be appritiated, Thanks.
  3. Hey guys im going to purchase some tire. Whats the best tire for loose dirt hillclimbs? thanks
  4. Ill think about it. because if i sell em i cant afford new ones haha
  5. haha i figured just makin sure
  6. Hey guys my tires are pretty much slicks now and i need new ones. But my quad has a 10 inch rim and i cant seem to find a decent tire for a 10 inch rim. Also can i put a tire meant for a 9 inch rim on a 10 inch rim? Thanks
  7. sounds stupid but try vinegar and tin foil
  8. thanks guys i think ima go ahead and get on of those
  9. Hey guys i just got a pair of pro taper contours and need a new spot for the key, im just looking for some ideas pictures would be nice. Thanks
  10. try dissconnecting the parking brake, mine did the same thing and that was it
  11. hit all corners with a rubber mallet, should come off
  12. I clean mine every ride and i avoid water but still have dust problems and my carbs actually got so much dust in them once the throttle stuck but i cleaned them. I think i might try the box, thanks for the help.Oh and mine has outerwear.
  13. Just throwing my 10 cents in, my buddy had a dirtbike doing the same thing and it was just the head gasket.
  14. I have k&n pod filters on my quad now. But the get clogged up really fast and the bike starts to bog till i clean them. Im getting sick of cleaning the mid-ride. I ride in mostly woods and train tracks with occasional water, Whats the best filter set up? It has toomey t-5s on it now. Also will i have to re-jet?
  15. Thanks (bluebanshee98) i disconnected the tors brain and that was it. Thanks for all the help guys.
  16. i checked spark already i got spark and im cleaning jets first thing tommorow morning, thanks for all the help.
  17. Ok thank you. so if im right, its like a cheap tors eliminator? But my bike will idle forever, so i dont understand how it could be the tors.
  18. no its not, ive actually heard about that befor, what does it do?
  19. I thought about the tors being it but that happened to my buddies banshee and it wouldnt even satrt. I dissconnected the parking brake already, so that aint it. Ive never heard of the burn harness and no it didnt backfire.
  20. I dindt try that yet i had to clean the carbs when i bought the bike but it was fine all day today i was hitting the powerband fine so i figured it couldnt be jets but ill try tomorow
  21. I have just started having problems with my banshee today, i was riding it and it was fine and then it just bogged out and stalled. i tried starting it again and it will idle fine but when i give it gas it dies. I towed it home and cleaned it. I changed the spark plugs and cleaned the filters (Pod filters) and that wasn't it. Please help, any advise would be highly appritiated. Thank you.
