banshee604 Posted April 12, 2012 Report Posted April 12, 2012 i am having trouble with my carbs after a top end rebuild. i have idle, no mid throttle power and lots of top end. 1) i see black line with no throttle in the chambers but when i crank the throttle i do not see the red lines for syncing they move simultaneously i have adjusted them with the carb top adjusters 2) do you adjust the with the idle with the idle screw, so do you screw it in so the slide are a little raised for desired idle rpm???? the reason i ask is i was watching a video on mikuni carb on you tube and this guy said that your slides should be all the way down and the idle relies on the pilot jet any thoughts im sorta lost 3) i have no mid throttle power it bogs out, ran great before i took it apart there was a tiny hesitation near the top before the power band but nothing major so im assuming the mid throttle has to do with the air screws, so when u adjust 1 do you adjust the second the same since the identical carbs or are they a bit different, is there a metering tool for this? here is the link to that carb video looking at it again mabey that was to change the low end fuel mixture any help would be awesome thanks i just want to rip on my power house check it out on you tube Quote
Jereme6655 Posted April 12, 2012 Report Posted April 12, 2012 yes...you adjust the idle using the idle screws.....it very sligtly raises the slides. did this problem just start happening or was it a problem before you rebuilt the top end? have you cleaned the carbs recently? changed anything else on the bike? modified any part of it? Quote
special06shee Posted April 12, 2012 Report Posted April 12, 2012 check your carb slides.. you might have them in backwards or mixed up.. the side of the slide with the higher radius goes toward the filter side!! Quote
slothman Posted April 12, 2012 Report Posted April 12, 2012 Do you have aftermarket pipes? What pilot jet are you running? What main jet are you running? Are the slides rising at the exact same time when you ease into the throttle ? What is the current setting of your air screws (how many turns out) ? Also as mentioned make sure the dome part of the slides are facing the rear of the bike. Quote
banshee604 Posted April 12, 2012 Author Report Posted April 12, 2012 i dont think you can put them in backwards ill check tonite yes i have lots of mods on my bike check my profile i started the air screw at 2 turns out and adjuster out ward at 1/2 turn intervals on each carb Quote
banshee604 Posted April 12, 2012 Author Report Posted April 12, 2012 they were totally in backwards what a tard i am, 1 stupid thing thats all it takes hope i can get the air screws right now ill try tonite see if it works Quote
