i am having trouble with my carbs after a top end rebuild.
i have idle, no mid throttle power and lots of top end.
1) i see black line with no throttle in the chambers but when i crank the throttle i do not see the red lines for syncing
they move simultaneously i have adjusted them with the carb top adjusters
2) do you adjust the with the idle with the idle screw, so do you screw it in so the slide are a little raised for desired idle rpm????
the reason i ask is i was watching a video on mikuni carb on you tube and this guy said that your slides should be all the way down and the idle relies on the pilot jet
any thoughts im sorta lost
3) i have no mid throttle power it bogs out, ran great before i took it apart there was a tiny hesitation near the top before the power band but nothing major
so im assuming the mid throttle has to do with the air screws, so when u adjust 1 do you adjust the second the same since the identical carbs or are they a bit different, is there a metering tool for this?
here is the link to that carb video
looking at it again mabey that was to change the low end fuel mixture
any help would be awesome thanks
i just want to rip on my power house
check it out on you tube
