Koba Posted April 11, 2012 Report Share Posted April 11, 2012 Any one replace there shift arm seal? Im new to working on atv's let alone a banshee. Mines leaking and i was woundering how hard it is to replace and what else i might need to replace during the process? Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted April 11, 2012 Report Share Posted April 11, 2012 It's not hard. Just take off your shifter and pry the old seal out of there. Then slide the new one in. Chances are if that seal is bad there are others that are bad too. Quote Link to comment Share on other sites More sharing options...
slothman Posted April 11, 2012 Report Share Posted April 11, 2012 Any one replace there shift arm seal? Im new to working on atv's let alone a banshee. Mines leaking and i was woundering how hard it is to replace and what else i might need to replace during the process? Welcome aboard mate ! Just do a search on the board, and you can DL the service manual. It contains everything you need for this fix. Take your time and you will be OK as long as you have a small amount of mechanical experience. Have fun ! Quote Link to comment Share on other sites More sharing options...
Koba Posted April 11, 2012 Author Report Share Posted April 11, 2012 ok and is that seal the one on top of the trans where the clutch cable goes into the trans?? i was told thats what the seal was called. Im not to sure i dont wanna order the wrong seal.. Quote Link to comment Share on other sites More sharing options...
Acheron Posted April 11, 2012 Report Share Posted April 11, 2012 (edited) If it was anything like mine was to replace this past winter, you are in for a headache. Damn thing would not come out and I ended up breaking into tiny pieces to get it all out. Take your time if it won't just pop out. I used a small pick and small needle nose to get everything out. ~edit: Read wrong, thought you were talking shift shaft seal. Edited April 11, 2012 by Acheron Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted April 11, 2012 Report Share Posted April 11, 2012 You want the clutch arm seal. Wait, how is that leaking? Quote Link to comment Share on other sites More sharing options...
Koba Posted April 11, 2012 Author Report Share Posted April 11, 2012 idunno but it pools up right where the cable goes in hahaha... im confused too haha... but it pools up on top of the trans and runs in that valley just to front of that. and thats the only place trans fluid could pool up around there haha no other seal or anything on top. Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted April 12, 2012 Report Share Posted April 12, 2012 idunno but it pools up right where the cable goes in hahaha... im confused too haha... but it pools up on top of the trans and runs in that valley just to front of that. and thats the only place trans fluid could pool up around there haha no other seal or anything on top. Are you sure it is not premix running out of the carb overflow hoses and the gasoline is evaporating, leaving the oil behind? Quote Link to comment Share on other sites More sharing options...
dave5.0 Posted April 12, 2012 Report Share Posted April 12, 2012 Vents plugged and pushing out of the seal maybe? Shouldn't have anything coming out the top of the trans during normal operation. Quote Link to comment Share on other sites More sharing options...
