toytech Posted March 20, 2012 Report Posted March 20, 2012 sent kevin at hjr an email to get some pricing info, if i go thru with the porting and +4mil would there be anything else i would have to change besides my jetting??? he will need to cut your head for the 4mil Quote
kerv19 Posted March 20, 2012 Author Report Posted March 20, 2012 i think gonna stick with the porting, sprocket change, ported reed cages with new petals and tors eliminate. save the 4mil stroker build until next winter since i just put new pistons in it last june Quote
Strm Trpr Posted March 20, 2012 Report Posted March 20, 2012 Banshee crankshafts are pressed together from the factory and rely on interference fits between the connecting rod pins and the counter weights to hold it together. With the extra power your motor will be putting out from the porting, the increased compression from the head being milled and the timing advance, your crankshaft can potentially come apart. Send your crankshaft to whoever is doing your porting so they can true and weld it for you. You may just want to box up your entire motor and have them build it for you. That's what I plan to do. Quote
ClayAiken Posted March 20, 2012 Report Posted March 20, 2012 sent kevin at hjr an email to get some pricing info, if i go thru with the porting and +4mil would there be anything else i would have to change besides my jetting??? Im not an expert on 4mill's but your going to need diffrent domes and maybe a base gasket. Id ask Kevin about it. Quote
cline Posted March 20, 2012 Report Posted March 20, 2012 sent kevin at hjr an email to get some pricing info, if i go thru with the porting and +4mil would there be anything else i would have to change besides my jetting??? I also sent Kevin a similar email with questions about his 4mil set ups. He has a couple different choices or paths to go so as long as your questions are specific he will definately point you in the right direction. I asked about bearings, carbs, clutch, trans, and what he would recommend for the categories I just mentioned for the different packages he offers. Just be specific and you can't go wrong. Quote
Overboost Posted March 20, 2012 Report Posted March 20, 2012 sent kevin at hjr an email to get some pricing info, if i go thru with the porting and +4mil would there be anything else i would have to change besides my jetting??? yup, dump them T-6's and get some pro circuits or R2's basicly any pipe besides trinity or FMF Quote
Larry's Shee Posted March 20, 2012 Report Posted March 20, 2012 Couple things to think about. Check with your porter that he can re-do porting when you go 4mil, sometimes they can't depending on original porting. Good call on pistons for now, most 4mil are long rod needing different pistons. Quote
kerv19 Posted March 21, 2012 Author Report Posted March 21, 2012 i figured i would hold off until next winter when im not riding it to pull the motor and do a complete 4mil build. for right now im gonna get it ported and pray to god that it blows up so i have a reason to pulll the motor i will have to check with kevin at hjr to see if he can re port when i want to do a 4mil build, i hope he can because i need a little more power for the dunes this year. for some reason last year my banshee ripped 1-5 but once i hit 6th gear it fell on its face and would only bog down and im still confused at what it could be. Quote
special06shee Posted March 21, 2012 Report Posted March 21, 2012 i figured i would hold off until next winter when im not riding it to pull the motor and do a complete 4mil build. for right now im gonna get it ported and pray to god that it blows up so i have a reason to pulll the motor i will have to check with kevin at hjr to see if he can re port when i want to do a 4mil build, i hope he can because i need a little more power for the dunes this year. for some reason last year my banshee ripped 1-5 but once i hit 6th gear it fell on its face and would only bog down and im still confused at what it could be. two summers ago i had f.a.s.t. racing do a dune/play port... i ran t-5/ vforce 3/+4 timing/ stock carbs/ and a noss head with 20cc domes. i loved it!! thing was a beast for what i consider a "kinda stock bike"! i just had f.a.s.t covert this set up to a 4mil and what a huge difference but i also put some other goodies on as well! i would definently give Jeff at f.a.s.t a call and talk to him. he is a super dude and could for sure hook you up! Quote
fastbanshee8 Posted March 21, 2012 Report Posted March 21, 2012 There is nothing wrong with the FMF pipes. Quote
kerv19 Posted March 21, 2012 Author Report Posted March 21, 2012 two summers ago i had f.a.s.t. racing do a dune/play port... i ran t-5/ vforce 3/+4 timing/ stock carbs/ and a noss head with 20cc domes. i loved it!! thing was a beast for what i consider a "kinda stock bike"! i just had f.a.s.t covert this set up to a 4mil and what a huge difference but i also put some other goodies on as well! i would definently give Jeff at f.a.s.t a call and talk to him. he is a super dude and could for sure hook you up! That is my plan port now and 4mil later. glad you are happy with your shee There is nothing wrong with the FMF pipes. i agree with you, but for some reason i love the sound of toomeys over the rest of them. Quote
