jayc Posted February 27, 2012 Report Share Posted February 27, 2012 Put my 10 mil serval, 68 mm on a dyno, 98 hp without a complete tune. got about three runs in and my kick start gear came lose, C clip came off, and locked it up. Probably around 105 hp with it tuned. I will take it back for another dyno run soon. Got most of the parts from M & M. 38 mm Lectrons, V-Force 3, Shearer in frame small bores, Lock up clucth, 2-5 over ride trans, 6" over swingarm, Motowoz shocks, C 12 gas. Rode it today and it's faster than sh@#. Tranny works great, front end is hard to keep down. Heading to Glamis in a couple weeks, should be fun. Quote Link to comment Share on other sites More sharing options...
Dicklez Posted February 27, 2012 Report Share Posted February 27, 2012 Put my 10 mil serval, 68 mm on a dyno, 98 hp without a complete tune. got about three runs in and my kick start gear came lose, C clip came off, and locked it up. Probably around 105 hp with it tuned. I will take it back for another dyno run soon. Got most of the parts from M & M. 38 mm Lectrons, V-Force 3, Shearer in frame small bores, Lock up clucth, 2-5 over ride trans, 6" over swingarm, Motowoz shocks, C 12 gas. Rode it today and it's faster than sh@#. Tranny works great, front end is hard to keep down. Heading to Glamis in a couple weeks, should be fun. Any port work? Quote Link to comment Share on other sites More sharing options...
Dicklez Posted February 27, 2012 Report Share Posted February 27, 2012 Can you post the sheet? Quote Link to comment Share on other sites More sharing options...
SandmanPNW Posted February 27, 2012 Report Share Posted February 27, 2012 FAIL Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted February 27, 2012 Report Share Posted February 27, 2012 Why the heck would you do a serval with an override? Why not just do a cub... With that carb and pipe choice the serval cylinder seems like the total wrong way to go... Quote Link to comment Share on other sites More sharing options...
jayc Posted February 29, 2012 Author Report Share Posted February 29, 2012 Can you post the sheet? Andy at M & M posted it somewhere on here Quote Link to comment Share on other sites More sharing options...
jayc Posted February 29, 2012 Author Report Share Posted February 29, 2012 Any port work? Yes, Andy did some portwork Quote Link to comment Share on other sites More sharing options...
jayc Posted February 29, 2012 Author Report Share Posted February 29, 2012 Why the heck would you do a serval with an override? Why not just do a cub... With that carb and pipe choice the serval cylinder seems like the total wrong way to go... I wanted to try the overide....I will be doing some drags but a lot of dune riding...heading to Glamis in a couple weeks. The overide might not work out, if it doesn't I'll go back to stock. The torque numbers is what I was hoping for and they are at 57 ft. lbs. I think. 100 hp dune bike is pretty awsome if you ask me. How is dune riding with your cub? Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted March 1, 2012 Report Share Posted March 1, 2012 I wanted to try the overide....I will be doing some drags but a lot of dune riding...heading to Glamis in a couple weeks. The overide might not work out, if it doesn't I'll go back to stock. The torque numbers is what I was hoping for and they are at 57 ft. lbs. I think. 100 hp dune bike is pretty awsome if you ask me. How is dune riding with your cub? I don't dune ride with a cub... I drag race with it. I have a cheetah for the dunes. Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted March 1, 2012 Report Share Posted March 1, 2012 Thinking the same thing, almost sounds like your trying to build a drag bike with your other mods. That's exactly what I was thinking... Quote Link to comment Share on other sites More sharing options...
No Limit Powersports Posted March 1, 2012 Report Share Posted March 1, 2012 What makes it a drag bike? Because it has lectrons that are on gas??? Or shearers that work better than any other pipe we have tested from top to bottom? Or the fact that the dune bike has a duneable override? The serval has more useable power than any gas motor of the same size this bike will rock in the dunes. Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted March 1, 2012 Report Share Posted March 1, 2012 What makes it a drag bike? Because it has lectrons that are on gas??? Or shearers that work better than any other pipe we have tested from top to bottom? Or the fact that the dune bike has a duneable override? The serval has more useable power than any gas motor of the same size this bike will rock in the dunes. Big carbs, drag pipes, long swinger, override transmission... your guys' idea of dune riding is probably different than ours up here if thats a dune setup. If the owner is happy with it and its what he wants thats what matters. On a side-note, why the name-change? Jared Quote Link to comment Share on other sites More sharing options...
No Limit Powersports Posted March 1, 2012 Report Share Posted March 1, 2012 So on a serval you think small carbs and a diff pipe will make more usable power? 6 over is def as long as I would go and still dune it but with a 100 hp he will need it. his setup is very nice. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted March 1, 2012 Report Share Posted March 1, 2012 Big carbs, drag pipes, long swinger, override transmission... your guys' idea of dune riding is probably different than ours up here if thats a dune setup. If the owner is happy with it and its what he wants thats what matters. On a side-note, why the name-change? Jared Come on now, start paying attention!! http://bansheehq.com/forums/index.php?showtopic=152114 Quote Link to comment Share on other sites More sharing options...
No Limit Powersports Posted March 1, 2012 Report Share Posted March 1, 2012 On a side-note, why the name-change?<br /> <br /> Jared<br /> <br /><br /><br /> Check out our post in the sponsor spotlight. Quote Link to comment Share on other sites More sharing options...
