How do you hold a cool head O-Rings in place?
Thanks for the great ideas......I will see what available locally and make it happen. Thanks!
Silicone grease for urethane bushings is SUPER sticky and should not degrade o-ring. You could also use caliper slide pin grease but it's less sticky.
i use "transgel" used for holding automatic transmission parts in place. melts away after 130 degree's and just a very thin layer is needed so you dont run the risk of pushing a O ring out when installing it.
phelps uses "anal ease". its water based and he buys it in bulk so its always layin around....
