2fastinthepast Posted January 2, 2012 Report Posted January 2, 2012 I am putting my Chariot performance head together and the O-ring fall out....they seem small but Chariot says they are right. Whats the best way to hold them in place for installation? Quote
Dicklez Posted January 3, 2012 Report Posted January 3, 2012 I am putting my Chariot performance head together and the O-ring fall out....they seem small but Chariot says they are right. Whats the best way to hold them in place for installation? Some light grease on the orings Quote
BelleauCarl Posted January 3, 2012 Report Posted January 3, 2012 Glue them in place with some white grease Its the way a made Quote
jasons Posted January 3, 2012 Report Posted January 3, 2012 the things mentioned above works. i always use vaseline. Quote
2fastinthepast Posted January 3, 2012 Author Report Posted January 3, 2012 Thanks for the information! You guys helped me out................ Quote
badassbanshee479 Posted January 3, 2012 Report Posted January 3, 2012 i use either alil silicone or some wheel bearing grease... i also stretch them out just a tad before i put them in there grooves Quote
So Cal Suspension Posted January 3, 2012 Report Posted January 3, 2012 Just FYI, any petroleum based products have a tendency to degrade o-rings. I've always kept a stick of regular old chap stick in my tool box, and use that in all the o-ring grooves. Works perfect, and water based. Quote
kthurm Posted January 3, 2012 Report Posted January 3, 2012 I've heard that lotion and stuff like that wear down o rings too, that might not be true. I just play it safe and use grease Quote
So Cal Suspension Posted January 3, 2012 Report Posted January 3, 2012 I've heard that lotion and stuff like that wear down o rings too, that might not be true. I just play it safe and use grease Most lotions have petroleum products in them. edit: In case you didn't know, grease is 100% petroleum. Quote
Phelps Posted January 3, 2012 Report Posted January 3, 2012 i use "transgel" used for holding automatic transmission parts in place. melts away after 130 degree's and just a very thin layer is needed so you dont run the risk of pushing a O ring out when installing it. Quote
sangheraent Posted January 3, 2012 Report Posted January 3, 2012 I used to use vasoline and it was shit compared to bel ray waterproof grease. i have dropped my cool head and the orings stayed in place. I dont really care about the degrading I find a reason to open the cool head every year and I havent really seen any serious wear. Quote
mpd579 Posted January 3, 2012 Report Posted January 3, 2012 i used "gasket glue" and it worked just fine ??? Quote
2fastinthepast Posted January 3, 2012 Author Report Posted January 3, 2012 Thanks for the great ideas......I will see what available locally and make it happen. Thanks! Quote
answ3r Posted January 3, 2012 Report Posted January 3, 2012 Thanks for the great ideas......I will see what available locally and make it happen. Thanks! Silicone grease for urethane bushings is SUPER sticky and should not degrade o-ring. You could also use caliper slide pin grease but it's less sticky. Quote
springer Posted January 3, 2012 Report Posted January 3, 2012 i use "transgel" used for holding automatic transmission parts in place. melts away after 130 degree's and just a very thin layer is needed so you dont run the risk of pushing a O ring out when installing it. phelps uses "anal ease". its water based and he buys it in bulk so its always layin around.... Quote
