Small block twister question?
volvo63'
i have the same size motor as ban565, they can be set up with a good bit of different variables, stroke/bore/intake size (bolt up flanges)/exhaust flanges(again bolt up flanges).
mine made real good power on just motor.
http://67.199.65.66/twistercrankshaft/store/store_view.cfm?store_area_id=22&STORE_DEPT_ID=286
Edited by lowriderb
It is a billet cylinder block made by Twister. Bore sizes range from 68 to 78mm. It uses an iron sleeve. They have tripple ports and boost ports. They come with what most would consider a dune port, and have plenty of material left to be hogged out and custom ported however you want. They have a much larger coolant capacity than competitors cylinders, and better coolant flow characteristics. They have changeable intake runners and exhaust flanges. You can run stock banshee reeds or YZ250 reeds, and small-bore or big-bore pipes. They are a great cylinder and I would recommend them to anyone.
Here's a Twister Big-Block for comparison...
I have been thinking seriously getting Twister block after my stock cylinders retires. If I fak up a nicasil it will cost me a fortune to get them fixed. No one in Finland can´t do that.
What kind of power the stock port Twister will make with pump gas (4mm, 68 bore)? What are the "Best bet" pipes for it?
I don´t know why, but I can find much info about them.
New bore and hone costs about 80 dollars (60€) here, and it´s local shop.
We don´t have dunes here, so I don´t know how is the "dune port", so what are the numbers?
Thanks.
-Pasi S.
are those seadoo power valves on those cylinders?
So would you guys recommend a serval or 10 mil cub or this cylinder? Also what's the big difference between the interchangeable reed sizes.
the cub motors were designed to use the style parts that you already had, reeds, intakes, head.. the mini twisters are complete top ends similar to the cheetah's. the advantages of them are the intakes and exhaust flanges are interchangable so you can change things on the motor yourself as you want.
the iron sleeves can be bored out or changed out to bigger sleeve sets, i have heard of them going as big as 78mm's with the mini's but they are advertised to go up to 75..
It is either stock intakes of cr125.............it does not use yz250 as posted above..............
Depends on which generation of the small-block you have. There have been 4 generations of the small-block since it was released. You CAN find them with YZ250 reed cage intakes. :cheers: Either way you go, they are an awesome cylinder.
