robert0762 Posted November 22, 2011 Report Posted November 22, 2011 title says it all. I need to strip a coated swingarm but dont have any access to blasting. Quote
andrew3160 Posted November 22, 2011 Report Posted November 22, 2011 title says it all. I need to strip a coated swingarm but dont have any access to blasting. Aircraft grade paint remover. Should be able to get it in the paint section at any auto parts store. Quote
rubberneck Posted November 22, 2011 Report Posted November 22, 2011 Aircraft grade paint remover. Should be able to get it in the paint section at any auto parts store. Yup thats pretty much it. Depending on the quality and type of powder it can be a real bitch and may take a few coats but it will get it Quote
Buckwheat Posted November 22, 2011 Report Posted November 22, 2011 I used to buy an aerosol gasket remover at NAPA that would bubble automotive paint up within seconds of spraying it on. Don't know if it would work on powder coat. Wheat Quote
bansheesandrider Posted November 22, 2011 Report Posted November 22, 2011 Loys of sandpaper and a power sander and ALOT of elbow grease!!!!!!!!!!!!! Quote
coryv4 Posted November 22, 2011 Report Posted November 22, 2011 get some aircraft remover and put a thick coat on it let it sit for about 20 mins WEAR GLOVES or you will get chemical burns. then get a wire brush and it should brush right off Quote
87sheerips Posted November 22, 2011 Report Posted November 22, 2011 Find someone with a burn-off oven. The only way to go Quote
jbooker82 Posted November 23, 2011 Report Posted November 23, 2011 Find someone with a burn-off oven. The only way to go Yep. If your doing the powdercoating your self and have an old crappy oven you use. If it has a self oven clean feature you might try it. They usually get pretty hot and it might get it done. Quote
