yfz 450 pegs?
themechanic
I'm posting this for future Banshee Owner's looking for information on this topic and wanting to upgrade the OEM Banshee Foot Peg's using the Stock YFZ-450R/X Race Peg's.
Answer: Yes, the 2009+ YFZR-450R/X Pegs will fit the Banshee with very minimal modification. You need to cut or grind a spacer off the back of the peg on the PTO (Clutch) slide. Then you need to take a small carbide bit and slot all four holes 3mm on the YFZR/X Peg's and that's it...... Other than one fine thread foot peg bolt that is a little longer.
I pasted a tool list thats required to complete the foot peg swap successfully bellow:
- Take Off YFZ-450R/X Racing Foot Pegs.
- Four Inch Grinder w/ 80g Sanding Wheel.
- One Longer Foot Peg Bolt For Right Side Peg.
- Pneumatic Die Grinder w/ Small Carbide Porting Bit.
- 15mm Open Box End Wrench
- Can Of Brake Cleaner & Anti-Sieze for the foot peg mounting hardware.
  • 2 weeks later...
  • 1 year later...
