CPI
barranquilla
I thought by the diameter of the stinger tubes.
I would only use out of frame pipes on a purpose built drag racer that sees a groomed track. Out of frame pipes weigh a little more and dont mount as solid as an inframe pipe. There is a lot of weight mounted way from your banshee and rough terrain can tear them up.
How can i tell the difference between cpi out of frame small bore pipes and cpi out of frame big bore pipes??
On most pipes its the diameter of the stinger. I know a couple companies change the shape, length and diameter of the expansion tube as well as the stinger.
