barranquilla
Recent Profile Visitors
barranquilla's Achievements
  1. Couldnt find them on ebay, do you know how to look for them?
  2. https://www.google.com.co/search?q=2008+banshee&espv=2&biw=1097&bih=607&tbm=isch&imgil=eW2DHFJxQsvryM%253A%253B3kIZnrGgGRFubM%253Bhttp%25253A%25252F%25252Fyamahapictures.blogspot.com%25252F2012%25252F04%25252F2008-yamaha-banshee-350-atv-pictures.html&source=iu&pf=m&fir=eW2DHFJxQsvryM%253A%252C3kIZnrGgGRFubM%252C_&usg=__7-Zf6Ggeg8SEq9R63dqPLNmQcrw%3D&ved=0ahUKEwiEy9rnk-rQAhUE3SYKHd30CEoQyjcIIw&ei=5TtMWMTELoS6mwHd6aPQBA#imgrc=eW2DHFJxQsvryM%3A where can i buy these fenders and graphics in blue? thanks
  3. Jbooker82 where did u buy them??
  4. Vrx 46 the black color way, thank you
  5. Where can i buy oem 97 banshee graphics??
  6. Are there any slick tires for stock 9 inch rims? If not for 10'?
  7. Will cpi inframes work well on a NOT ported 4mm long rod crank, vforce 3, .50 oversize pistons, and timing plate? What timing would you use on the timing plate?
  8. Will cpi inframes work well on a NOT ported 4mm long rod crank, vforce 3, .50 oversize pistons, and timing plate, stage 2 jets. What timing would you use on the timeing plate?
  9. De donde crees?
  10. the prob is im buyin a set online and idk if theyre big or small bore and my only reference is a picture
  11. How can i tell the difference between cpi out of frame small bore pipes and cpi out of frame big bore pipes??
  12. I have a pair of keihin 34 carbs and i havent figured out what size jets to install. i have fmf powercore2 timing plate dynatek coil and cdi box and 4mm longrod crank and .50 oversize pistons.
  13. whats the difference other than how they look?
  14. so cpis and port job it is
  15. What if i dont have a port job done? and if i do will it still run good with 89 octane gas
