i took out a spark plug and i hooked a compression gauge to the sparkplug hole on the head and i kicked it 3 times with the key off.
kick it a good 20-30 times per cylinder only way to do it just to make sure and 100 psi seems pretty low
its a 2000 that has never had new rings so im wondering if i should tear it down and fresh up the top end, and no madder how many times i kick it it will only go to about 100-105 psi
then you prolly just need new rings pull the head off and check piston to cylinder clearence and make sure ur cylinder isnt scored up
yeah this winter thats what im going to do, and clean everything up and repaint everything to make it look like new. and i called arroung stock banshee compression is 115-120 and mine is at 100-105 in 10 years i lost 10psi i dont think thats tooooo bad
what is the difference between cylinders? generally 90psi is the rebuild point, but a good seated set that gets regular use and no sticky build-up can pump out good right up until the day they snap from being worn down. a quick check is the best way to be safe, and you might want to just plan on a re-ring
I found this 'chart':
Sea Level 1000' 2000' 3000' 4000' 5000'
18cc 197 178 171 170 165 145
19cc 183 167 160 158 152 137
20cc 169 156 149 146 140 129
21cc 156 145 138 134 128 121
stock 130 125 118 112 106 100
on this thread:
http://bansheehq.com/forums/index.php?showtopic=68439&st=0&p=581714&hl="compression%20chart"&fromsearch=1entry581714
hope it helps.
Edited by vifferman
im not ported all stock banshee, and i have no clue on my sea level, im in michigan if that helps. and if 90 is the rebuild point im ordering rings today lol
where at in michigan? 100 is gettin pretty low....but its not totally to the rebuild point. and depending if the rings are what has worn or if the cylinders have worn down into a egg shape from natural wear.......just ordering rings could be just a bandaide fix....
