3Yamaha5Banshee0
Everything posted by 3Yamaha5Banshee0
  1. and another problem i have been having with my Pod Filters is that at a idle you give it gass and it will rev up then back down and then slowly rev back up when your thumb is off the throtle, any ways to fix that?
  2. every banshee i have heard with pipes (dont madder the kind) are always wayyyyy toooo lound and i hate it
  3. How did you do the compression check? I always take a plug out put the threded thingy in were the plug was at and with the Key OFF kick it 3 times
  4. thats funny because i was JUST looking at them tires on the internet lol, sound like a good deal too
  5. Holeshot is a pretty popular tire, i have heard nothing but good things about them. i think i might go with them my next pay check lol
  6. trails, grass, dirt road kinda an all arround tire
  7. I still have the stock Dunlop tires on my 2000 banshee they are getting really worn down, i was wondering what is the BEST tire for the rear. Im looking for something with a low profile tire that site level on the ground and not like a balloon Thanks, Dustin
  8. yeah most water my bike sees is from wet grass, and if im thinking correctly i think i have to have a jet of 280 is that correct?
  9. I just bought some K&N air filters i put them on a rejetted my carbs and i started it up... every times i give it gass you can ear the carbs sucking air, it dont sound verry "cool" its actualy pretty loud is there any way to stop this from happening? AND is it even a good mod to use? or should i go back to the huge and hard to install air box?
  10. i think a stock banshee off the show room floor has 125-135 compression, my 2000 all stock is running about 100-105. guy in my local ATV repair shop said that a bike anywere under 50psi will not run thats the limit
  11. i did some investigating and when you first start it up (cold) it back fires every 3-4 seconts untill its warmed up. and only on the right cylinder. i cleaned carbs again and hooked that choke tube back up on the correct nipple and it still does it
  12. dude the oil in your gass is what lubes your piston rod bearings, with absoutly no oil its going to seize up big as shit. no oild your running ti way to lean and hot, my burn a hole right in the top of the piston.... and yeah sounds like im a noob...
  13. Klotz smells so bad lol, and you dont run any oil? i will see you in the next "BANSHEE ENGINE REBUILD" in the Images fourms
  14. What oil should i run in my banshee and what mixture, im running AMS oil domonator in it right now at 50:1
  15. i have done all of that pleanty of times, i still dont understand
  16. i think i just threw up a little.... them plastics are a combo of shit and more shit
  17. i havent tore into it yet but this winter (if i make it that long) im going to tear it all apart and see whats going on. i hope i can just hone the cylinder and put new rings and a gasket set on the top end and we will be smooth sailing
  18. i just put my powercore 2 silencers on and they arent loud at all, its the pipe that makes it louder
  19. im not ported all stock banshee, and i have no clue on my sea level, im in michigan if that helps. and if 90 is the rebuild point im ordering rings today lol
  20. i checked that a few times, it is hooked up and sealed good
  21. i just ordered a set of Powercore 2 silceners for my banshee, im going to put them on my stock pipes. will they be alot louder then my stockies???
  22. i have a 2000 stock banshee. the left cylinder is smoking alot more then the right AND the right is back fireing. anything i can do?
  23. to be more then 100% clear i think they are junk, a plastic straw would do just as much
  24. I boguth my banshee with a boost bottle now what in the hell does it do? lol
  25. i did that and all i got was about 105 psi
